It's best to shift the trans manually going up and down hills. The kickdown is best left for passing maneuvers. You want to stay in the middle of the
power band. By the time you were at 20 MPH you should have been in 1st gear. Keep a close eye on your oil and coolant levels at this time. Be sure
your overflow has about 2/3 full of coolant. And watch gauges for normal ranges.
John Lebetski
Woodstock, IL
John Lebetski
Woodstock, IL
