> Folks, there seems to be a new kid on the block for our older engines.
> Its called NANO PRO MT
> http://nanopromt.com/
> It is advertised as a protection at the Nano size which fills in rough spots on the engine metal.
> This is suppose to make the engine run smoother, cooler with less friction and less heat.
> In regards to our older cam type lifters, I wanted to know if this "oil stabilizer" could be used with todays oils and not need a zinc additive to
> protect against the rough friction of the cam type lifters.
> I sent a request for more information to NANO PRO MT offices, and received the following....
> Larry
> The Nano materials work well in any oil application and work especially well in older engines. As long the oil you are using works well we will
> make it work better! Zinc along with other metals was added originally to reduce wear and increase heat transference. We do it more efficiently by
> impregnating the metal cuticles and greater surface area. For added performance drop in a bottle of Nano Cool and you will have the best 1-2 punch
> for reducing heat, cavitation and wear in a mechanical application.
> Hope that helps, Thanks!
> Can anyone add any input, pro or cons toward this product?
> It is now being sold as an oil stabilizer and sold at Auto Zone exclusively. Black bottle with a white camo label and on sale during their
> promotion for $19.99.
Larry,
This is interesting, I am going to keep looking at.
Unfortunately, I no longer have an engine lab at my disposal to do some testing.
> Larry
Larry,
