Harrison four bag bolts
LarryW
6,031
758
113
Menomonie, WI.
I've got everything together to install a Harrison four bag system on my coach ACCEPT for the bolts that hold the bogies and Harrison to the frame.
Anybody out there know the length of bolt needed for this? The Harrison that I obtained is used off of a parted out coach, and came to me without the
bolts. I could take it apart an add the thickness of the Harrison to the length of the old bolts, but would prefer to have the corrected bolts on
hand when I get that far into the project. TIA
Larry
78 Royale w/500 Caddy
Menomonie, WI.
Larry,
Are you asking about the 2 big bolts at the bottom of the pedestal? If so,
those are not bolts, they're the "bogie pins". The original nuts on the
outside, threaded, ends of the pins are replaced with 2-part nuts. The
larger part of the nut has a threaded shoulder onto which the pedestal
sits, with another nut on the threaded end of the shoulder holding the
bottom of the pedestal on the shoulder. That was Leigh's work-around to
prevent needing new, longer, bogie pins.
Off the top of my head, I don't recall any other bolts except those holding
the bags in place. Those should be easy to figure out. Let me know if you
need me to go refresh my memory (from '98 when I installed mine).
On Fri, Apr 17, 2020 at 10:30 AM Larry via Gmclist
> the
> Larry
> Menomonie, WI.
