Harrison Brakes are on the agenda this W/end: Success
heinz wittenbecher
1,470
Well, almost success. Still have to connect the electrics on the Mico lock.
Gary, what did you hook the low pressure switch up to? the horn relay or a
seperate alarm?
Heinz
www.bytedesigns.com/gmc
BTW, the brake difference is beyond words, but I'll try as soon as some time
available to update the website.
> Heinz:
> Have you given any thought as to where you'll locate the Mico lock?? I'm
> assuming you got it from Leigh??
> Although I've yet to install mine, I've noticed pictures in car magazine's
> of them located next to the master cylinder, in fact they're plumbed right
> into it.
> Paul Bartz
> From: Gary Miller [mailto:grizzly]
> Sent: Thursday, January 13, 2000 11:45 PM
> I did the whole job last summer. Don't see how I survived without it.
> Now I feel in control again. The brake lock REALLY works -- I can hold
> my coach with toad on my driveway and you know my driveway!! You'll like
> it.
>> I'm finally getting around to working on the buggy this weekend.
>> Will be upgrading the TSM's on the front rears to Leigh's brakes.
>> Will also be installing his Master Cyl, Booster, Brake Lock and Front
>> Calipers.
>> Anyone done any/all of it lately? Any words to the wise?
Heinz--
I could see no use for the alarm feature (same conclusion that Leigh came to
IIRC) so I did not hook it up. I have an added electrical fuse/relay panel
which has both ignition and battery sources with lots of fuse blanks. This is
where I hooked the momentary B+. I can't see where it makes much difference
where you connect as long as it is not switched by the ignition. BTW, I have
left my micro-loc "on" for a week without any leakage; brakes locked tight
Gary
North Bend, Oregon Coast
> seperate alarm?
> Heinz
Gary,
Alarm aside, the wiring diagram on mine shows a DPST switch, not a momentary
contact. I.e. to keep the lock engaged 12V power is maintained to the
solenoid. Did you install with a latching relay or is it a typo :-) ?
I'll probably put the alarm on a warning light as a 'Brake fluid leakage'
indicator.
Heinz
> Heinz--
to
panel
This is
difference
have
> Gary
lock.
a
> > seperate alarm?
> > Heinz
time
If you got the same switch I have (MICO, don't have #), power is needed only
when locking the brake. A momentary contact is all that is needed -- no relay.
To lock the brake, you apply full pedal pressure, then hold the power switch
"on", release brake pedal pressure, then release the "on" switch. The lock
stays locked until brake pedle pressure is heavily applied again (no switching
needed). HTH
Gary
> Gary,
> indicator.
> Heinz
> > Heinz--
> to
> panel
> This is
> difference
> have
> > Gary
> lock.
> a
> > > seperate alarm?
> > > Heinz
> time
I guess I'll find out when I get it wired up.
The switch that was included is an on/off and the label says turn on switch,
apply brake.
To disengage, turn switch off.
Perhaps different model of Mico.
Heinz
> relay.
> needed). HTH
> Gary
>> Gary,
>> indicator.
>> Heinz
>>> Heinz--
>> to
>> panel
>> This is
>> difference
>> have
>>> Gary
>> lock.
>> a
>>>> seperate alarm?
>>>> Heinz
>> time
Heinz--
I surely would not want the parking brake to be dependent upon a voltage being
applied to the valve. If that is the kind of valve you have, send it back!
Gary
> apply brake.
> Heinz
> > relay.
> > needed). HTH
> > Gary
> >> Gary,
> >> indicator.
> >> Heinz
> >>> Heinz--
> >> to
> >> panel
> >> This is
> >> difference
> >> have
> >>> Gary
> >> lock.
> >> a
> >>>> seperate alarm?
> >>>> Heinz
> >> time
Gary,
Any chance you have a partnumber of the Mico Lockvalve, i.e. number on the
box?
Heinz
> Heinz--
being
back!
> Gary
switch,
> > apply brake.
> > Heinz
needed only
no
> > > relay.
switch
lock
switching
> > > needed). HTH
> > > Gary
> > >> Gary,
momentary
leakage'
> > >> indicator.
> > >> Heinz
> > >>> Heinz--
came
> > >> to
fuse/relay
> > >> panel
blanks.
> > >> This is
> > >> difference
BTW, I
> > >> have
tight
> > >>> Gary
Mico
> > >> lock.
relay or
> > >> a
> > >>>> seperate alarm?
> > >>>> Heinz
some
> > >> time
Heinz:
Although my brake lock isn't installed yet, one I got from Leigh is Model
Number 02-620-009 and the label beneath that has: MBL 3 PWS.
Paul Bartz
Sent: 1/18/00 10:58 PM
Gary,
the
box?
Heinz
> Heinz--
voltage
being
back!
> Gary
switch,
> > apply brake.
> > Heinz
needed only
no
> > > relay.
power
switch
The
lock
(no
switching
> > > needed). HTH
> > > Gary
> > >> Gary,
a
momentary
the
leakage'
> > >> indicator.
> > >> Heinz
> > >>> Heinz--
Leigh
came
> > >> to
fuse/relay
> > >> panel
blanks.
> > >> This is
much
> > >> difference
BTW, I
> > >> have
locked
tight
> > >>> Gary
the
Mico
> > >> lock.
relay or
> > >> a
> > >>>> seperate alarm?
> > >>>> Heinz
as
some
> > >> time
Paul,
I just have a date underneath, but it's the same model number.
Heinz
> Heinz:
> Paul Bartz
> From: Heinz Wittenbecher
> Gary,
> the
> box?
> Heinz
>> Heinz--
> voltage
> being
> back!
>> Gary
> switch,
>>> apply brake.
>>> Heinz
> needed only
> no
>>>> relay.
> power
> switch
> The
> lock
> (no
> switching
>>>> needed). HTH
>>>> Gary
>>>>> Gary,
> a
> momentary
> the
> leakage'
>>>>> indicator.
>>>>> Heinz
>>>>>> Heinz--
> Leigh
> came
>>>>> to
> fuse/relay
>>>>> panel
> blanks.
>>>>> This is
> much
>>>>> difference
> BTW, I
>>>>> have
> locked
> tight
>>>>>> Gary
> the
> Mico
>>>>> lock.
> relay or
>>>>> a
>>>>>>> seperate alarm?
>>>>>>> Heinz
> as
> some
>>>>> time
