Skip. ( If your interested. I have a new one on hand cheeper then you can =
get one anywhere. ) That part is mostly an harmonic dampener. As about a=
ll internal combustion engine have RPM points. That cause damaging harmonic=
s to build up in the crankshaft. And can break the crankshaft if unchecked.=
That's why the outside part is riding on rubber. I've made modifications =
to engine that change the original harmonic levels. And the RPM points. Tha=
t's part of the reason some people break their crank. And it's also a =
part of the balancing system. That's why it has an unusual shape. The =
double roller will last a long time. ( But so will the stock chain. ) They=
where developed for higher RPMs, and heavier loads brought on by more aggr=
essive cam lob profiles. As then with the more aggressive cam lobes. You t=
hen need higher valve spring pressures. Then it comes down to the fact that=
we don't have any of these conditions that the double roller chain was de=
signed for to start with. Kind of negates the reason to install one. I repl=
aced the original chain in a friends 78 Royale. That had about 150,000 mile=
s on it. Chain was fine. The aluminum/plastic cam gear was the issue. Stuck=
with GM stock. Some builds put in the roller chains, High volume oil pump=
s, high strength rod bolts, and some Mondello high performance parts. Soun=
ds like great upgrades. So if these items are great improvements. Why didn'=
t the GM engineering department put these parts in to start with? GM built =
these engines to do a task. And we use them just as GM meant for them to be=
used as. And put a warranty on. I've built GMC engines just as GM did. I'=
ve build some GM engines that can run at 8,000 RPM's all day. Put out more=
then double the HP/torque that GM ever even dreamed of. These engines must=
have upgrades because of these extreme demands. This is in upgrade territo=
ry. Not in, as built for designed operation. Face it. GM knows more about =
their engines then anyone. If these so called upgrades were needed. GM woul=
d have used them in their build. I know enough to know that I'm NOT smarte=
r then the GM engine engineering department. Bob Dunahugh
