Ham Antenna Mounting
jack christensen1
264
I'm wondering what experience Hams have had with mounting VHF/UHF and HF antennas on GMC's and how they've solved them. Since the body is fiberglass, the usual VHF/UHF antenna would need an additional ground plane, and a mag mount won't work either. Also, I'm thinking of mounting a screwdriver antenna for HF. Have folks mounted them on the ladder?
Thanks,
Jack Christensen - K6ROW
'76 Glenbrook/Clasco
Sebastopol, CA
My 2 meter / 440 antenna is mounted in the center (side to side) of the roof in the aluminum portion just in front of the hole for the exhaust fan or front air conditioner. It is about 2 feet behind the OEM radio antenna. I have a 5/8 wave Antenna Specialist style antenna up there. That location has a good ground plane and is on the highest spot available on the coach. I have never got around to putting my screwdriver and FT-100 in my GMC. I have seen a couple of people put screwdrivers down low on the rear bumper while driving and then move it to a ladder mount up high when parked. You sure do not want it up high when driving in case you hit a tree limb or something. I would hate to loose a several hundred dollar screwdriver to a tree or low bridge.
My choice for the 2 meter antenna location was easy for me because a PO had already installed a chicken band antenna there. I simply unscrewed it and threw it away. Then I reused the mount and coax for 2 meters. 75 to 90 miles on 50 watts to a repeater site in flat land country in not uncommon using that mounting location.
I run mobile HF in my Blazer but I have never got around to doing it in my GMC. John Richardson and Dan Gregg both run screwdrivers in their GMCs.
Jack,
We have 5 dual band antennas on MOBY with a 22' deployable mast with 2 TV
cameras, and a GP95 (2meter, 440, & 1.2Gig )
Almost all of the dual banders are Mag-Mounted on the roof - with additional
plates glued down for a doppler unit.
the mast stores in one piece above the awning, and the stinger with antennas
& camera store inside and makes a really big paper towel rack.
The Mast sits on a "convert-a-bal stinger on the trailer hitch & we build a
wingnut clamp mast mount on the spare tire holder.
We also support 4-5 operating positions..
For HF, we normally deploy a additional truck with a 85' hydraulic mast.
Trey Shannon,
CEM, MT, MEP
PO 4524
Ft Worth TX 76164
tron
817-735-4871
Cell - 817-737-8739
Texas Disaster Response Pool Inc,
TXDRP.ORG
> Date: Thu, 08 Apr 2010 00:26:19 -0500
> From: Jack Christensen
> Subject: [GMCnet] Ham Antenna Mounting
> To: gmclist
> Message-ID:
> Content-Type: text/plain; charset="ISO-8859-15"
> Thanks,
> Sebastopol, CA
Jack,
For VHF/UHF I have an MFJ on-glass antenna mounted on the
drivers window. For HF, I have a Yaseu ATAS screwdriver
antenna mounted to the ladder.
> Thanks,
Jack, I have my aprs 1/4 wave mag mounted to the refer vent cover. I am looking for a 2 ft. cb ant to put behind it.
Got my 2/440 on the glass, like Terry.
I have built several screwdrivers and have two now. But, not on GMC yet. I have no ladder on there right now. So, I have a bumper mounted hustler with automatic tuner. Hustler is mounted on a 2 ft extension on rear bumper, to get coils above the top of GMC. Works. Was temporary setup 4 years ago. I still want to mount my screwdriver but as I am retired, I seem to have no time for it right now, getting it mounted.
Dan
Dan & Teri Gregg
danandteri.blogspot.com
///Halon Automatic Fire Extinguishers
I mounted a 2-meter antenna on an L-bracket, bolted to the stock mirror mount. The antenna is a 5/8-wave whip, which can work without a ground plane pretty well. It's so hilly around here that I would not want to characterize its performance, but when there is line of sight, I have no trouble, even at low power.
That antenna uses an NMO mount, which came with 10 feet or so of what looks like RG-174--really narrow stuff. I ran it along the groove between the rubber windshield gasket and the body, and then hang it over the wiper shaft and run it into the hatch. I used a couple of wads of black butyle rubber to hold it in place, and it is surprisingly unobtrusive there.
I've never attempted a mobile HF application.
Rick "KR9D" Denney
'73 Glacier 230 "Jaws"
As a recent purchaser of a GMC M/H, I'm wondering what
is the roof made of. I had always "assumed" that the
shell (top and sides) were sheet aluminum with cast
fiberglass end caps. Am I wrong here?
* D C "Mac" Macdonald *
** Oklahoma City, OK **
* "Money Pit" 76 x-PB *
Thanks, Dan.
In that case, any of the normal VHF/UHF ham antennas
that work against a ground plane should be satisfactory,
even outstanding with direct mounting on the roof.
Mounting a screwdriver HF antenna on the aluminum ladder
near the top should also be quite good as long as good
electrical contact can be established between the ladder
and the chassis and the roof surface. Tarheel has the
"Little Tarheel" and I forget the name that High Sierra
gives to its short antenna and these should prove very
satisfactory when mounted high on the ladder. These
are both claimed to be better than even the LARGER
screwdriver antennas mounted on the bumpers.
73 - Mac, K2GKK/5
* Mac Macdonald *
* Oklahoma City *
** "Money Pit" **
* '76 ex - P.B. *
Date: Thu, 8 Apr 2010 12:14:45 -0500
Subject: Re: [GMCnet] Ham Antenna Mounting
Roof and upper body is alum. Belt line down and endcaps
are fiberglass material of somekind.
Dan
Dan & Teri Gregg
I originally used some mounts I bought at hamfest that used "U-Bolts" to wrap around the uprights to the original tubular mirror mounts for VHF/UHF antennas. One on driver side for normal operations and the passenger side for the APRS system. This worked extremely well.
I have seen a screwdriver HF antenna mounted in the same place, using the same mount.
Since I have replaced the original mirors with RAMCOs (thanks for the mount help to jmk),I have used thru-the-glass mounts, again on both of the upper front side windows, driver's side normal ops and passenger side APRS. However, over this last winter both of these antennas have lost their grip on the glass. I need to re-glue them in place.
I do not have an HF in the GMC, but have a 857D to put somewhere. No real idea on the antenna for HF.
Tom Phipps,
KA4CSG & Marilyn KA4JKW
75 GMC Ex-Avion
You are pretty close. The center section of the roof is aluminum as
are the upper sides above the beltline.
The rest is a form of fiberglas that is called SMC.
Here is an article that I wrote for the GMCMI newsletter issue 96,
Summer 2006, that might be of some interest to you.
GMC FIBERGLASS REPAIR
The earliest 1973 vehicles have “hand laid”fiberglass, at least
for the front body assembly. Somewhere between serial number 24 and
50 this process became SMC (sheet molded compound). This was a new
composite material for use in the automotive, industrial, and personal
watercraft markets that presents unique repair problems. Parts made
with SMC are produced in compression molds, so they are smooth on both
the inside and outside. SMC parts do not have an outer gel coat, but
they are usually painted or color molded. When the paint is sanded
off, the underlying surface has a marble appearance. When damaged SMC
is sanded, short coarse fibers are exposed and a dryer powdery dust is
produced compared to conventional materials.SMC is a polyester-based
material, but it cannot be repaired with polyester resin. This is due
to the mold release agent that is present throughout the entire SMC
part. Unlike conventionally molded parts where release agents are
applied to the mold surface, SMC is compounded with them in the resin
mix for quicker processing. This means that as the damage is sanded to
prepare a good bonding surface, fresh mold release agent is exposed.
Polyester resin products are not strong enough to adhere to this
surface. SMC SHOULD ONLY BE REPAIRED USING EPOXY-BASED RESINS, FILLERS
AND ADHESIVES. For good adhesion, when painting, use only catalyzed
type paint systems -- at least for the primer.When a part is broken or
crushed, it is difficult to realign the pieces with each other because
the frayed fibers tend to “hang up” on one another. Use a saw
blade to cut the length of cracks or tears. This relieves the stress
on solid laminates which often return to their original shape with
little force. A router is excellent for removing damaged core
material without disturbing intact face skins. Try to remove as little
material as possible so the repair does not grow too large. However,
solid laminate must be exposed for a good repair.Next, support the
part so nothing gets distorted during the repair process. This can be
as simple as strips of 2 inch wide masking tape or as elaborate as a
custom-made clamping fixture. With the part supported, proceed to
preparing the bonding surface by grinding a taper or steps around the
damage. This is the critical step for functional repairs but it is
also the most overlooked and abused. If a taper is to be used,
measure the depth of the valley and calculate how far the sanding must
extend to achieve the desired ratio. Mark the outer edge of the taper
using a marker and begin sanding inward toward the valley. Be sure to
remove material slowly so the taper progresses evenly. Wet the entire
bonding area with resin, then begin saturating each ply of
reinforcement before it is placed. Work on a sheet of plastic so the
fabric can be easily lifted from the table once it is ready. A
flexible rubber squeegee is the best tool for spreading the resin
evenly through the fabric and removing excess which may be present.
Place the reinforcement into its spot on the repair, ensuring the
proper orientation. Stop every few layers to compact the patch as much
as possible. A squeegee or grooved roller works well for this.
Continue stacking the repair plies at right angles until all the
material that was removed has been replaced. A final cover layer is
then added over the entire area. Sand before painting.
Emery Stora
77 Kingsley
Santa Fe, NM
My APRS antenne (and it's GPS antenna) are mounted on the fridge vent
cover and the radio package for that is
in a plastic bin that I put in there when we take the coach out.
To remount your on glass antennas, go to your local automotive paint
store and get the BLACK 3M trim adhesive tape.
It is thinner and stronger than the gray stuff. Comes in a 1" wide
roll. You can also use the Larsen/Radiall re-install kits and
just cut the tape to size.
