I am the 3rd owner of a 1977 GMC Palm Beach that has a set of "Hadley
Horns" mounted on the roof. These horns were not functional when I
purchased the motorhome. The previous owner had no info on them.
I can not find a model number or any ID info, but if the top plate is
removed, there is thin "shim" type metal plate that sits over the air
chamber. There is also a plastic hose connected to the horns. I can
access this by removing the driver side speaker/light assembly, but I
can't get up to the bottom of the horns, where they are mounted to the
roof. to check the connection. (I don't want to remove them from the
roof if possible)
Are these horns "air' or "vacuum" drive? There is a lanyard type
actuator hanging down in the cab, that is attached to some type of
valve on the horn assembly. I attempted to connect them to an air
supply, but still got no sound.
Any info on operation, ID, "getting them to work" or ??? will be
appreciated.
Thanks in advance ............
HR in Indy PB'77
Harold Curson
9675.0203
roof if possible)
appreciated.
HR in Indy PB'77
Harold Curson
9675.0203
