grounding rear speakers?
hstanton
23
Greetings all,
Is there any real time experience or advice out there on grounding the
rear speakers to a replacement stereo/tape unit? I know Wes Coughlin
recomended doing it to achieve the fade control. What does it really
involve? I wuld appreciate any helpful hints.
David Graves
Beltsville, MD
Royale center kitchen
My experience with the speakers in the sound system might be helpful. The
original sound system in my '76 Birchaven uses common ground to the chassis
for all speakers. This method of wiring will burn out any new stereo. I
know, I burned two out. The ground wire in the dash does not go to the
speakers if you connect to it you will loose your radio. I finally had to
run new wire - two conductor - from the speakers to the dash. How you run
the wire will depend on your coach. I hope this helps.
Rick
Warrington, PA
'76 Birchaven
- -----Original Message-----
Sent: Tuesday, May 09, 2000 7:27 AM
To: gmcmotorhome
Subject: GMC: grounding rear speakers?
Greetings all,
David Graves
Beltsville, MD
When I was doing the upgrade of my speakers I was told that one can purchase
a "common ground" adapter. This little box allows you to use the old common
ground speakers with a modern stereo system. I checked into it and found
that crutchfield ( http://www.crutchfield.com/ ) had these adapters.
I decided that I wanted to use new speakers rather than save the old ones,
so I ran new speaker cable. (pain in posterior).
The speaker mount in rear is not really very stable and there is a lot of
vibration. I regret working with these old locations. If I had it to do
again, I'd leave the old 4X10 speakers in place, and put some new ones
elsewhere.
Tony Bad
To:
Sent: Tuesday, May 09, 2000 10:44 AM
Subject: RE: GMC: grounding rear speakers?
chassis
> Rick
> Warrington, PA
> '76 Birchaven
> From: hstanton [SMTP:hstanton]
> To: gmcmotorhome
> Greetings all,
> David Graves
> Beltsville, MD
Ours is a 75, so any switch was after that year
Tony B.
To:
Sent: Tuesday, May 09, 2000 11:43 AM
Subject: Re: GMC: grounding rear speakers?
> purchase
common
> It should be noted that this affects only the older models of the GMC. I
> have forgotten which year the change over was made, but later models do
not
> use the common ground speakers. On the later models you can switch to
better
> speakers without doing any rewiring.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
Well Emery, it appears the switch over was from 76 to 77. I have a 76 with common ground, and you have a 77 with +/- two conductor wiring.
Rick
76 Birchaven
Warrington, PA
To: gmcmotorhome
have forgotten which year the change over was made, but later models do not
use the common ground speakers. On the later models you can switch to better
Emery Stora
77 Kingsley
Santa Fe, NM
Our '76 Royale (TZE366V101510) has the 2 conductor wires. Maybe transmodes
were changed over first.
HTH
Dave (advisor/navigator & Dege, pilot etc.), '76 Royale, Santa Barbara, CA
My 76 has new style TZE266v101791
Bill
> Take Care
> Arch >>
> Must have been in late 1976 or early 1977 since my 77 Kingsley has
> the newer
> style.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
My '77 Kingsley has the two wire system also.
Marion Hope
George M.(Marion) Hope, Ph.D.
1930 SW 19th Way gmhope
Gainesville, FL 32608 gmhope
(352) 371-2795 (Home) (352) 846-2111 (Office)
>Greetings all,
>David Graves
>Beltsville, MD
In our 73 they were grounded, BUT when I installed the new SONY tape/cd
unit, the instructions were very clear to NOT use a grounded loop, and DO run
good wiring to handle the load...
John & Brenda Szalay
Louisville Ky
73 Blue Yonder :)
> transmodes were changed over first.
No....'cause x66V100878 was built 632 coaches earlier than x66V101510
David Lee Greenberg
GMC Motorhome Registry
Dedicated to the preservation of the Classic GMC
http://www.gmcss.com/registry.htm
