Gray and black water tank readings
jane field
22
I am having a problem with my tank electric read-outs. One tank is reading
full when in fact it is empty. I cleaned the leads on the outside of the
tanks, but one tank is stills reading full. I think it is the black water
tank.
What else might I try.
Chuck Field
77 Royale
Jane,
If you still have the factory senders, there is very high chance that they have failed. The original construction of the senders was that water could get into the variable resistors and they fail. They are not repairable and not available, but there are several fixes that you can use.
A new style dry electronic sensors are available that are a direct bolt in and wiring.
http://www.appliedgmc.com/prod.itml/icOid/839
and
http://www.appliedgmc.com/prod.itml/icOid/838
I did it this way and they work well.
Now a more cost effective route is to use this:
http://www.appliedgmc.com/prod.itml/icOid/1181
I have this in our coach now and it does work fine. They are a probe unit and does require adding probes to the tanks and some wiring.
JR Wright
GMC Great Laker MHC
GMCGL Tech Editor
GMCMI
78 GMC Buskirk 30’ Stretch
1975 GMC Avion (Under Reconstruction)
Michigan
> tank.
> Chuck Field
> 77 Royale
I think Chuck has a Coachman, so there mist be paper stuck on the sensor.
Fill the tank about 1/3 full and jerk as you drive as the water need to
slosh on the rear side.
> Jane,
> and wiring.
> and
> JR Wright
> GMC Great Laker MHC
> GMCGL Tech Editor
> GMCMI
> Michigan
> reading
> water
> > tank.
> > Chuck Field
> > 77 Royale
Chuck,
I can get you new style sensor screws that tends to over come that issue.
> On Sun, Sep 3, 2017 at 2:41 PM, John Wright
>> Jane,
>> in and wiring.
>> and
>> JR Wright
>> GMC Great Laker MHC
>> GMCGL Tech Editor
>> GMCMI
>> Michigan
>> reading
>> the
>> water
>> > tank.
>> > Chuck Field
>> > 77 Royale
>> > GMCnet mailing list
>> GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
