gravity bleed procedure? (semi-stranded)
ek_lektro
170
Good morning GMC’ers,
After a 6 hour drive, and RIGHT as i pulled into our campsite, the brakes gave out, and the light came on. (At least we made it to the spot!) (But… the campsite is on a hill… extra points)
There’s brake fluid all over the inside of the rear-most driver’s side wheel, and i’m pretty sure the leak is coming from the rusty line itself, but not 100% sure. Do they ever leak from the cylinders themselves? To see if i could confirm the leak spot, i tried adding fluid and pumping the brakes, but there must be too much air in the lines, ‘cause i’m not getting any additional visible leakage this way.
We’re out in the middle of nowhere, and i understand that for an emergency repair, i could carefully kink the offending line, do a gravity bleed, and run on 5 brakes; but fortunately a friend was arriving to the camp site one day behind, and was able to pick up a brake line, extra fluid, 3/8” flare nut wrench.. and PB Blaster. So i soaked the nut and adjuster last night, ready to go.
I’ve assisted with brake jobs many times over the years, but i was always the guy pumping the pedal up front, so i’ve never done the bleeder screw myself! My guess is that i loosen it up counter clockwise, and that once fluid comes out without bubbles, tighten it back up?
And as far as “gravity bleed”, Do i need to jack up the front? or is the height of the master cylinder enough that gravity should take its course?
Since the fluid was not low in the rear chamber, i’m guessing i don’t need to bleed the fronts, but probably will need to bleed the other side, rears?
And.. if i can get a friend to do the brake pumping, is this method more effective at all with the engine running?
Many thanks for any quick tips… (and i’m on the digest version of the list, so direct replies appreciated :)
Standing by, ready to go, cheers
Greg
SolarSonic (semi-stranded at the Symbiosis Festival :)
Inside of the wheel sounds like wheel cylinder to me. Saturated linings. If
one wheel cylinder has failed, others aren't far behind it. Disconnect the
hard line from the wheel cylinder and screw the fitting into a female
matching fitting with a short piece of line crimped off on it to seal up
the system. Bleed the rear brake system, drive it to someplace where you
can jack it up and remove the drums ( repair facility) and rebuild the rear
brakes. All of them. Check the fronts too. Bleed the entire system.
> ready to go.
> Greg
No need to run engine for bleeding brakes.
Fill master cylinder with fluid, replace lid,
Pump up brake pedal and hold, open the bleeder, brake pedal goes to the
floor, close bleeder,
again
again
Open master, make sure there's plenty of fluid, (don't let it run out)
Repeat until there is no more air evident in the line.
Top off master with fluid.
Normally this is done for each wheel, starting with the one furthest from
the master. Your situation might be an exception.
Gravity bleed is for overnight or more.
Other replies solicited to Ek_Lektro
bdub
> ready to go.
> Greg
Of course, Jame H 's solution is more of a complete, for keeps, solution.
bdub
> the system.
hey James, thanks for the tip.
and i should’ve put a little more detail into my original post,
but a ‘bit' more of the fluid seems to be coming from an area where the rusty line is rubbing against the back of the wheel mount. couldn’t visibly see a leak coming from there specifically, but if i had to put my money on it.. well.....
and with the wheel turning around, i think a drip is gonna make the inside of the wheel mostly wet. so i’m 90% sure its just the line,… (also ‘cause i’m pretty sure the cylinders were changed about 5 yrs ago, during the last rear brake job,.. though that doesn’t necessarily mean anything!)
Greg,
I have done a lot of both gravity and vacuum bleeding.
Somewhere there will be an high school auto shop teacher beating his head against a wall, but....
Given you know you blew a brake line, start with that wheel first. You may not need to bled the others.
After the line is replaced, leave that wheel cylinder open. If you have some clear tubing that is a help.
Fill the master cylinder about twice, then run around and see if solid fluid is coming out.
If it is, close the bleeder and try the brakes.
If it isn't go refill the master cylinder and let fluid run while you watch. If you don't see solid fluid in a few minute, close the bleeder and
check the reservoir level. Top it up and let it run again.
When you get bored, test the pedal feel. If it is pretty solid, try driving it.
If the pedal does not got to the floor, drive it home and then you can do a good bleed.
That happened to me in Southern Louisiana leaving a rally. I went to the closest auto parts store and bought either a cap or a plug and sealed off
the line for that wheel only. Then I filled up the master cylinder and opened the cap / plug until the fluid drained out. I let it run while and kept
the master cylinder filled up so no new air could get in the line. After about 1/2 small can of fluid ran through it I closed the cap / plug. I
drove it home to NW Indiana on 3 rear brakes and never knew the difference.
That was a lot easier than trying to repair it on the spot. Later I replaced all 4 rear wheel cylinders. They are cheap.
To all reading and contributing to this thread, as the "posters" brake warning light
came on, might he need to "reset" the shuttle in the combination valve before he can get
fluid to the rear brakes? Will someone who knows about this please post how "Ek" can tell
if the combination valve needs resetting. If the brake light is still on with the engine running
is that an indication the valve is "overcenter"?
DAVE KING
lurker, wannabe
Toronto, Ontario, Canada
well, i got the old line off and the new line in… (easier said than done, had to carefully use a torch,
‘cause even 48 hours of PB Blaster and a 3/8” flare nut wrench still started to strip, on one of the fittings )
we pumped and bled the rear-most wheel to get things started, but now trying gravity bleed.
tomorrow is when we need to leave the campsite, so we’re on schedule.
we’ll see if the brake light goes away or not.
thanks all!
greg (ek_lektro)
Update: After putting in the new rear brake line and starting a gravity bleed yesterday,
this morning we figured we’d hurry things up by reverting to the usual pump and bleed method; and now everything seems back to normal.
The brake light is OFF as well.
Thanks everybody for contributing your knowledge to this successful field repair!
cheers
Greg
SolarSonic, taking the slow road home…
Victory, Save travels
Mid Michigan
Glad you were successful! Cheers and safe travels!
JD Lisenby- USAF Ret
1978 Royale-455
Electromotive Tec2 FI & ignition
Navarre, FL
