Golby Fuel tank senders
gary j zingle
326
Some of you might remember that I put my fuel tanks in
a couple of months ago. Thought I should be O.K.
The tanks were in excellent shape, replaced all hoses,
clamps etc. Neither sending units were functioning so
they were replaced with new ones from Golbys.
New GM rubber O rings were used and new GM lock rings.
Completed this work almost 2 months ago and when I fueled
up gas was obviously spilling onto the ground from the
top of the rear tank.
Today I pulled the offending tank. I found a trail of dust
that clearly showed that the leak was from the sending
unit. When I removed the sending unit it was clear that
the O ring had not sealed, although the O ring was well
centered. These O rings with the tabs to hold them
centered are nice.
Had given up finding the problem (I hate that when I
give up and start to put something back together without
finding the source of the problem).
During reassembly I found that the sending unit could
shift off center. Compared the new sending unit to the
GM version. The GM version uses a light steel sheet
(about 16 gauge) to seal against the tank. This sheet
has a ring formed that looks like it would be good at
preventing the O ring from shifting. The Golby unit uses
a thicker steel plate (about 12 gauge or 1/8" thick) to
seal against the tank. It has no formed ring. Therefore
the O ring only has the formed depression in the tank
to help it stay centered.
No problem with the O ring. It had stayed centered.
The problem was with the sending unit. It didn't have
to stay centered. The formed ring on the GM sending unit
would have not only kept the O ring from shifting,
but would have also served to keep the sending unit
centered.
Once the Golby sending unit was installed using special
care to keep it centered. I plugged all the lines and tested
the seal with the tank upside down and some gas in it.
No leak!
Put the tank back in and filled the tanks as full as possible.
No leak!
Success at last! It only took me 2 months :)
Arch if I remember correctly you used the Golbys sending
units as well. If you haven't found your problem I suggest
you might want to check this out.
Anyhow with the fuel tank problem behind me, (before noon ! )
I was able to move onto more mission critical issues like
installing the light in the fridge :). Got to be able to get a beer
after dark without waking my son :) =
PS - As a side issue, if the land speed record team needs
a fuel tank re and re man for the pit crew I think should apply.
It doesn't take me long to do this anymore!
PPS - Another side issue. I took the drive to gas up today.
Haven't driven the old girl in close to 2 months. I have to make
a point of driving the coach at least once a month. The enjoyment
of using it exceeds any bad feeling I might get when something
does not go as planned the first time.
Regards
Gary Zingle
1973 GMC 26 foot
Enjoying another beautiful day in Edmonton
Ed wrote;
>I had Golby's senders put in my coach..... the gas was
>running under the coach and down the driveway of the station.
>CAUTION, BEWARE WHEN INSTALLING NEW SENSORS, CHECK FOR LEAKS WHEN FILLING
UP.
Gasoline leaks in any vehicle are COMPLETELY UNACCEPTABLE, imho.
Thats a red light emergency- Find a better solution, just repositioning the
parts is a bad idea. Not much margin to cover any
deterioration/corrosion/deformation/impacts.
The seal should be positvely retained so there is absolutely zero chance it
will be the weak link that causes failure.
Surely we can find a better way to make the Golby sender work than by guess
or by golly. I'd feel awful if a GMC and or GMC owner was lost for a 50 cent
part like a seal. Tech guys, better re-engineer this one!
Brent Covey
AMEN! I don't know what you guys paid for those, but whatever it is, chalk
it up to experience and buy the right ones. Please! I've gotten fond of your
posts.
Travis
- -----Original Message-----
To: gmcmotorhome
Date: Monday, August 30, 1999 8:27 AM
Subject: Re: GMC: Golby Fuel tank senders
>Ed wrote;
>UP.
cent
>Brent Covey
> Gary
> Thank you! I thought from the moment I got the Golby units that I had
> been suckered. I did not like them. Then when the gas started pouring
> out of the tank----well I was more convinced. Then when Cinnabar's news
> letter came last week and it said the new senders were self centering--
> well it was another nail in the coffin. Now with your mail I just want to
> hit somebody (not politically correct---I know). Well, maybe with the net
> we can get some of this junk off the market. Battery trays that only let
> you see one battery and flat senders----what can I say. Hang in there
> folks----only we can save ourselves. Without the net we would not have
> known that others were in the same boat.
> Take Care
> Arch 76 GB IL
Arch/Gary:
I had the same reaction when I changed out the sending units on my tanks. Only
I was thinking of more than just hitting someone when told by Golby they wouldn't
take back the sending units I'd just purchased from them! Even though the design
is not correct for this application. They told me not to worry, that it would work
just fine! Ha! (to the sound of the cash register...)
My coach currently still has the Golby units on it, and I keep my fingers crossed
that it stays OK for a while, as the Cinnabar units cost quite a bit more than
Golby units.
Must be that critical ring in the seal sheet that makes them so expensive!! ^_~
Anyway, I plan on changing these out when I save up some $$. I just really hate to
pay twice for something! As far as I see it, Golby has lost my business for good,
and I'll return those Golby units sometime when I'm driving by their place. Maybe
they won't be open...won't make any difference to me!!
Tom Henderson - Houston
'76 Birchaven
http://www.members.tripod.com/gmc76
Guys
Golby people will probably be at GMCI Convention. Maybe they should hear from you in
person. I know that I will be buying from Cinnabar on this item, when I drop my tanks
this winter.
Thanks to everybody for the heads-up. I have noted my cross-referance book.
Wayne Newland F9300 75 Palm Beach
> > Gary
> > Take Care
> > Arch 76 GB IL
> Arch/Gary:
> Golby units.
> '76 Birchaven
Wayne:
I hate to disappoint you. However, I've missed two GMCMI conventions since
Myrtle Beach in Mar 1995 and I only recall seeing Golby at the Titusville FL
one, in Mar of 1996.
Odds don't look good!
Paul Bartz
Sent: 8/30/99 10:19 PM
hear from you in
drop my tanks
this winter.
book.
> > Gary
had
pouring
news
centering--
want to
the net
let
there
have
> > Take Care
> > Arch 76 GB IL
> Arch/Gary:
tanks. Only
they wouldn't
the design
it would work
fingers crossed
more than
> Golby units.
expensive!! ^_~
really hate to
business for good,
place. Maybe
> '76 Birchaven
Paul
Someone from Golby was at Marion, NC.
Wayne
> Wayne:
> Paul Bartz
> From: Wayne Newland
> hear from you in
> drop my tanks
> this winter.
> book.
> > > Gary
> had
> pouring
> news
> centering--
> want to
> the net
> let
> there
> have
> > > Take Care
> > > Arch 76 GB IL
> > Arch/Gary:
> tanks. Only
> they wouldn't
> the design
> it would work
> fingers crossed
> more than
> > Golby units.
> expensive!! ^_~
> really hate to
> business for good,
> place. Maybe
> > '76 Birchaven
Wayne:
I was there too, however I did not run into them?? Did they have a vendor
space and display anything?? I rode up and down that street on my bike at
least twice a day and never noticed them??
You don't mean Zeb Frady, do you??
Paul Bartz
Sent: 8/30/99 11:16 PM
Paul
Wayne
> Wayne:
since
Titusville FL
> Paul Bartz
> From: Wayne Newland
> hear from you in
I
> drop my tanks
> this winter.
> book.
> > > Gary
> had
> pouring
> news
> centering--
> want to
> the net
only
> let
> there
> have
> > > Take Care
> > > Arch 76 GB IL
> > Arch/Gary:
> tanks. Only
> they wouldn't
though
> the design
that
> it would work
> fingers crossed
> more than
> > Golby units.
> expensive!! ^_~
> really hate to
> business for good,
> place. Maybe
> > '76 Birchaven
Paul
Yes, on vendor row. Came in on Monday, if I remember, complete with cut-aways
Wayne
> Wayne:
> Paul Bartz
> From: Wayne Newland
> Paul
> Wayne
> > Wayne:
> since
> Titusville FL
> > Paul Bartz
> > From: Wayne Newland
> > hear from you in
> I
> > drop my tanks
> > this winter.
> > book.
> > > > Gary
> > had
> > pouring
> > news
> > centering--
> > want to
> > the net
> only
> > let
> > there
> > have
> > > > Take Care
> > > > Arch 76 GB IL
> > > Arch/Gary:
> > tanks. Only
> > they wouldn't
> though
> > the design
> that
> > it would work
> > fingers crossed
> > more than
> > > Golby units.
> > expensive!! ^_~
> > really hate to
> > business for good,
> > place. Maybe
> > > '76 Birchaven
Wayne,
Are you sure you're not confusing Caspro with Golby. Chuck Stoddard of
Caspro is the only vendor that I remember with cutaway parts. He drives a
blue and white 23 footer. I was at Marion until Thursday and I gotta' agree
with Paul - if Golby was there it was definitely a "stealth" presence.
Patrick
> From: Wayne Newland [mailto:wayne]
> Sent: Monday, August 30, 1999 11:52 PM
> To: gmcmotorhome
> Subject: Re: GMC: FW: Golby Fuel tank senders
> Paul
> Wayne
> > Wayne:
> they have a vendor
> > Paul Bartz
> > From: Wayne Newland
> > Paul
> > Wayne
> > > Wayne:
> conventions
> > since
> > Titusville FL
> > > Paul Bartz
> > > From: Wayne Newland
> they should
> > > hear from you in
> this item, when
> > I
> > > drop my tanks
> > > this winter.
> cross-referance
> > > book.
> > > > > Gary
> units that I
> > > had
> > > pouring
> when Cinnabar's
> > > news
> > > centering--
> mail I just
> > > want to
> Well, maybe with
> > > the net
> trays that
> > only
> > > let
> say. Hang in
> > > there
> we would not
> > > have
> > > > > Take Care
> > > > > Arch 76 GB IL
> > > > Arch/Gary:
> units on my
> > > tanks. Only
> told by Golby
> > > they wouldn't
> > though
> > > the design
> > that
> > > it would work
> I keep my
> > > fingers crossed
> cost quite a bit
> > > more than
> > > > Golby units.
> > > expensive!! ^_~
> some $$. I just
> > > really hate to
> > > business for good,
> driving by their
> > > place. Maybe
> > > > '76 Birchaven
Patrick
Yep, I made a mistake. Sorry to everybody.
Wayne
> Wayne,
> Patrick
> > To: gmcmotorhome
> > Paul
> > Wayne
> > > Wayne:
> > they have a vendor
> > > Paul Bartz
> > > From: Wayne Newland
> > > Paul
> > > Wayne
> > > > Wayne:
> > conventions
> > > since
> > > Titusville FL
> > > > Paul Bartz
> > > > From: Wayne Newland
> > they should
> > > > hear from you in
> > this item, when
> > > I
> > > > drop my tanks
> > > > this winter.
> > cross-referance
> > > > book.
> > > > > > Gary
> > units that I
> > > > had
> > > > pouring
> > when Cinnabar's
> > > > news
> > > > centering--
> > mail I just
> > > > want to
> > Well, maybe with
> > > > the net
> > trays that
> > > only
> > > > let
> > say. Hang in
> > > > there
> > we would not
> > > > have
> > > > > > Take Care
> > > > > > Arch 76 GB IL
> > > > > Arch/Gary:
> > units on my
> > > > tanks. Only
> > told by Golby
> > > > they wouldn't
> > > though
> > > > the design
> > > that
> > > > it would work
> > I keep my
> > > > fingers crossed
> > cost quite a bit
> > > > more than
> > > > > Golby units.
> > > > expensive!! ^_~
> > some $$. I just
> > > > really hate to
> > > > business for good,
> > driving by their
> > > > place. Maybe
> > > > > '76 Birchaven
Wayne,
No problem - takes a man to admit it! Probably my turn next!
Patrick
> Patrick
> Wayne
> > Wayne,
> > Stoddard of Caspro is the only vendor that I remember with
> > cutaway parts. He drives a blue and white 23 footer. I
> > was at Marion until Thursday and I gotta' agree with Paul -
> > Patrick
After all the discussion about the Golby Fuel tank senders, I decided
to add my two cents worth.
If any of you are going to the GMCMI convention in Forest City, please
feel free to look us up. We would be more than happy to tell you our
less than happy experience with Mr. Golby. It is too long a story to take
up space here, but we will NEVER do business there again.
Kara Kosier
77 EII
To:
Sent: Monday, August 30, 1999 11:12 PM
Subject: RE: GMC: Golby Fuel tank senders
> Wayne:
since
FL
> Paul Bartz
> From: Wayne Newland
> hear from you in
> drop my tanks
> this winter.
> book.
> > > Gary
> had
> pouring
> news
> centering--
> want to
> the net
> let
> there
> have
> > > Take Care
> > > Arch 76 GB IL
> > Arch/Gary:
> tanks. Only
> they wouldn't
> the design
> it would work
> fingers crossed
> more than
> > Golby units.
> expensive!! ^_~
> really hate to
> business for good,
> place. Maybe
> > '76 Birchaven
>Ed
>Well, you are number three. Lets see how many more we can find. I was
>wanting to start this thread when I explained my problems after
>installing the senders. Gary guess you got the job done. Thanks!!
Add another. Mine is intermittant, but still had a major leak in Texas. NOw
I get to take off my access cover and check things out.
Henry
Soquel, Ca 95073 / IP reviews
fax: (831) 462-5198
>> Gary
>> been suckered.
- -snip-
for good,
place. Maybe
I stopped by Golby's while I was in Orlando last week. An interesting
place. Some things were exactly as original - just with the Golby name on
them. OTOH, other parts were not exact but represented as being identical
to the originals. To be "fair" soem of the guys behind the counter seemed
to know their stuff. But a few were order takers in the worst sense of the
phrase.
I hope that the customer service that I saw improves. We may need original
fiberglass parts someday.
Henry
fax: (831) 462-5198
