GMCNet Portional Valve (update)
thomas r whitton
72
Update on proportional valve replacement.
This is an update on replacing the proportional valve.  I  sprayed "witches brew" penetrating oil (50% acetone, 50% ATF) for four days.  On the fifth day I used a pencil torch on the line nuts to the valve then, while still hot and pushing the nut counter clockwise with a line wrench, I repeatedly hit the wrench where it was overlaying the nut with a hammer.  The line slowly came loose from the nut with each hammer blow.  The procedure worked on three of the five lines but didn't work on two.  (The first two I worked on and went to school on.)  Unfortunately, I cork screwed the two lines that run to the master cylinder and will be replacing them.  These lines run through several  tight spaces that I have made tighter by adding accessories over the years.  I could remove everything to run new brake lines but that would just make the job infinitely harder.
I got on Google for brake line lessons.  I'm impressed with the ease of working with NICOPP tubing (nickel-copper).  I watched the factory man and then a couple of real life mechanics.  NICOPP apparently has more than adequate PSI capacity, is easy to bend, flare and will not rust.  Do any of you have experience with this tubing?  What's the downside, if any?
Here's one of my Google lessons: https://oppositelock.kinja.com/the-truth-about-copper-brake-lines-1818499200
I look forward to your thoughts.
Tom Whitton26 foot updated GMCPaducah, Ky
I was trying to get you to heatit and soak it hot every day. Not just the last day.
If you had enough room, cut off the end of the two lines and flare them in place again.
I haven't used it but looks like everyone sells it.
25 foot with15 fittings on Amazon for $21.00.
Ive used the Nicopp lines on my Coach, after a talk with Dave Lenzi. I got a better quality flaring tool and a tool to chamfer the ends. The
Chamfering is critical to get the double flare correct. A little practice and it was not too bad. The Nicopp bends very easy and is easy to work
with. Some of the stock lengths of line Advance Auto had did not have the correct nuts, so I got the nuts in a different pack and then installed
those where needed.
The lines have been on for 3 years and no issues with leaking or rusting. The nuts themselves are a different metal from the lines, but I do not see
any issues with the lines rusting to the nut, which is the problem most of the time.
77 Royale, Rear Dry Bath. 403, 3.55 Final Drive, Lenzi goodies, Patterson carb and dizzy.
Mid Michigan
> harder.
Nickel copper brake line is good stuff and easy to work with. Makes smooth easy double flares compared to steel. No rust no worry. I have a roll of
3/16 and 1/4 from Amazon.
Wally Anderson
Omaha NE
75 Glenbrook
Megasquirt III injection
Bob Stone hydroBOOOOST
Manny reaction arm system
Branscombe Kelsey Hayes park brake
http://wallyandsue.blogspot.com/
On Manny's advice, I got standard lengths from Advance for my transmission cooler lines. I'd do the same for brake lines - they bend fairly easily
with a fifteen buck Harbor Freight bender. If I have to make brake lines to replace unruly ones (i'm following this thread closely, the valve is my
next task) I'll cut the premade to the proper length and then borrow the flare tool from Advance - in the store. Nobody seems to ave success with the
cheeapo flaring tool.
--johnny
Braselton, Ga.
No one seems to agree with me but I've given up on double flares. I only use them if I have to.
I now do everything with 37 degree flares.
Why?
The flare is dead simple to make, I have a cheap flaring too that works everytime
they are reusable ( double flares are not supposed to be reused )
Ive never had a leak
the only downside is the fittings are slightly more expensive.
From: Gmclist on behalf of Johnny Bridges via Gmclist
Sent: Monday, January 29, 2018 2:04:35 PM
Cc: Johnny Bridges
Subject: Re: [GMCnet] GMCNet Portional Valve (update)
--johnny
Braselton, Ga.
> Why?
Kieth,
There is small problem with 37°(AN) flares in automotive hardware. There is a DOT spec that specifies 45° flares. Then there is the issue that
much of the required hardware is simply not available in AN. I do still have the AN flare tool that I bought when I worked on power plants. It was
expensive then. The real problem with double flares (pointed up in a ASTM study years ago) is that most that fail were not done right. This is
sometimes the fault of the technician and sometimes the result of the poor tooling available. I believe that your attention to detail can make up for
a less than great tool set.
Yes there are times when it's hard or impossible to use AN fittings, so then I don't or will use an adapter or use a pre flared section.
As far as the DOT spec, that doesn't worry me much.
Sent: Monday, January 29, 2018 8:41:27 PM
> Why?
Kieth,
