GMC
> get gmcmotorhome-list profile.form
I went with a system from Jardine. Used the Thorely headers and it
went together well. If going to the 3' system it seems that with the
stack headers you are not getting the full benefit of the better exhaust
breathing. I would also reccomend a K&N air filter to open up the
intake also. Also, if the heat from the Thorley is a concern, I had
the header coated by Swain Tech. with a ceramic coating that reduced
compartment heat significantly. The cost of the coating is #$200 and
you should get the headers unchromed. The ceramic will make the headers
last much longer.
