GMC trip
cbwood
101
>Thanks for reply,
>I looked at filler area from engine area/map pocket by driver seat and could
>not see any wet gas, there was gas odor.(was burntout on gas odor, even B/I
>propane. Did you see a leak on yours?
>Ron&Gina
>73 Pumpkin-Rose
>Ft. Mohave, AZ.
Talk about a pucker factor... Having gas running out on the ground near an exhaust pipe while filling up...
Yes, i replaced that hose...looked good but leaked like a sieve..I suspect some may be seeping out near top of hose. Mine would then run down hose to bottom and off to ground..If urs is just seeping, this might give you the smell and not see any running out. I had to pull my fender well panel to see/get to it..It's attached to body behind the panel and then runs to and down the main filler tube near frame. Gas backs up to this hose as the tanks are getting full. I put reinforced clear hose on mine and can see this happening. Mine wouldnt leak till it was getting full and kicked off.
HTH..
CBWood
CBWood
77 Kingsley
MWC OK
Get free personalized email at http://www.switchboardmail.com
Thanks again,
Got more time now, to check all that out. Just hoping its the lucky factor,
And be a easy repair.
Ron
To:
Sent: Tuesday, December 07, 1999 11:55 AM
Subject: re: GMC: GMC trip
> >Thanks for reply,
could
B/I
> >Ron&Gina
> >73 Pumpkin-Rose
> >Ft. Mohave, AZ.
> HTH..
> CBWood
> CBWood
> 77 Kingsley
> MWC OK
