>From watching the posts here it seems that some GMC's drive well and others
don't. Prior to purchasing my '75 PalmBeach I had owned two class C RV's on
GMC chassis and the handling of the GMC is awful by comparison.
The front end has new ball joints and fresh alignment. This improved things
somewhat but the handling is still poor. Everything in the front end seems
to be tight enough that it should work ok.
The rear bogies seem to be tight but on the right side the leading wheel
seems to be pointed about a half degree inward relative to the rear wheel.
It seems to me that at highway speeds as the vehicle sways to the right more
weight would transfer to this wheel which would tend to steer the rear of
the vehicle to the left creating an oversteer condition in the rear end.
This seems to fit the steering pattern I'm experiencing. The rear end has a
lot of side to side whipping that my other RV's didn't.
My manuals specify camber and toein but don't mention alignment of one wheel
relative to the other. I started out expecting to find worn bushings so
haven't actually measured toein at this point. This leading right wheel is
the one which is most likely to be damaged by running over a curb or
something so I would assume someone else has been here before.
Is a half degree difference between the wheels a problem or is there
something else I haven't found? If something is bent is it likely to be the
spindle, the arm or the mount. The spindle could be checked by chucking it
in a lathe and comparing the shaft relative to the flange but measuring the
other pieces would be much more challenging. Is there a way just to shim
everything into place?
Has anyone else been this route before? I would appreciate hearing of
anyone else' experiences.
Dick Kennedy
Dick Kennedy
