Gene-
Seeing that you have now converted to a single muffler, being the
careful man that you are, I presume you have already calculated into the
equation prior to the modification at least all of the following:
increased back pressure with only one muffler; reduced horse power on
hills; increased residual moisture and acid accumulation in muffler;
increased costs for more frequent muffler replacement; and increased gas
usage at the current high prices. Of course with the muffler at the back
you will naturally want to measure the number of degrees in lower
temperature it is running at so that will require temp. sensors on it
with a remote gauge up at the dash so you can note differences between
short trips versus long trips.
Just wondering, curious,and maybe thinking,
Claude
Claude
