Claude... you almost have it. Must have long alligator clips to connect
up, Have youself fastened so you will not fall into the engine
compartment. Then I think you have it.
al
> Now Gene , I'm trying to picture how this works. Your are going down the
> highway, and you get, if you are lucky, your better half to be in the
> drivers seat. You then open up the engine hatch and with all that heat
> and hot air and noise blowing in your face, you reach down to the exaust
> pipes with your digital voltmeter and try to grasp onto an electrical
> point without burning yourself. Hopefully the road is straight without
> curves or bumps. Likely you should have a hat on,so when the engine
> hatch falls on your head, the bald spot doesn't get bruised too much.
> And likely you should hae a few band aids and burn ointment handy in
> case you touch the exaust pipe in the process. yes I get the picture
> perfectly!!
> Claude
al
> perfectly!!
> Claude
