GMC Motorhome Digest V2 #564
ron & gina
397
Thanks Duane, I called a local Industrial shop and explained my air system.
They also told me to tube pressure switch to Tk. and to add water separator
and replace check if bad. I believe they were under $40 (they just gave me a
under price) for check&separator and some fittings. I already have a gauge
tubed to tk. could you tell me whats the and more in the Cinnabar kit?
Thanks for your help and info.
Ron&Gina
73 Pumpkin-Rose
Fort Mohave,AZ.
To:
Sent: Sunday, July 25, 1999 12:58 PM
Subject: Re: GMC: GMC Motorhome Digest V2 #564
> Ron & Gina
> GM placed the Air System's Pressure Switch in a bad place (Plumbing) on
> the early 73 & 74 coaches. The plumbed it between the compressor & check
> valve. This configuration did not have the advantage of the check valve
> in terms of leak down. Best to re-plumb the Pressure Switch to the Tank
> & have the maximum benefit of the Check Valve.
> Best investment for you Air System is the purchase of Wes Caughlan's
> (Cinnabar 1-800-720-2227) Air System upgrade Kit for your Power Level
> System (about $90). Kit includes SS Check Valve, Air filter (remove
> water), new Pop off valve, gauge & more. This is a must if you want to
> fix you air system & keep it operating properly.
> Duane Simmons
> ___________________________________________________________________
> Get the Internet just the way you want it.
> Free software, free e-mail, and free Internet access for a month!
> Try Juno Web: http://dl.www.juno.com/dynoget/tagj.
Thanks Gene, Nice GMC!!!& Toad. And nice and informative site which I have
used alot. So I guess the more in kit is just the fittings. I might check
local shop and see what I get for under $40. Thanks again!! Another ? Does
the overhaul kit (Dana pump) still work on pumps that don't have red head
gasket? mine(guard) faces the side on radiator and it don't look to have GMC
on it, but looks identical.
Ron&Gina
73 Pumpkin-Rose
Ft. Mohave,AZ.
To: ;
Sent: Sunday, July 25, 1999 5:17 PM
> -- [ From: chief evaluator * EMC.Ver #2.5.3 ] --
> there is more information and pictures on my web page
> gene
> -------- REPLY, Original message follows --------
> Date: Sunday, 25-Jul-99 06:40 PM
> From: Ron Gina \ Internet: (raideron)
> To: gmclist \ Internet: (gmcmotorhome
> .org)
> system. They also told me to tube pressure switch to Tk. and to add
> water separator and replace check if bad. I believe they were under $40
> (they just gave me a under price) for check&separator and some fittings.
> I already have a gauge tubed to tk. could you tell me whats the and more
> in the Cinnabar kit? Thanks for your help and info.
> Ron&Gina
> 73 Pumpkin-Rose
> Fort Mohave,AZ.
> From: duane m simmons
> To:
> > Ron & Gina
> on
> check
> valve
> Tank
> to
> > Duane Simmons
> -------- REPLY, End of original message --------
> Gene Fisher CA/OR/Palm Beach-GMC
> web page
> http://www.california.com/~eagle/
