GMC lug nuts (reply , further info)
philip l. stewart
287
Mark,
I don't believe threading a nut on top of the lug nut is a possibility.
There aren't any threads extending out of the OEM lug nut on the OEM
stud. I suppose I could tack weld a half nut on the crown of the lug
nut but that's a lot of effort (6 x 8 = 48) if an oversized lug nut
(about 1 1/8 inch tall) can be found.
The hub cap is the common 8 lug GMC black plastic part that's been used
for sometime on 3/4 ton and larger pickups. You've seen them
eveywhere.
Phil
