GMC Holley TBI
mr.c
494
Paul, you might want to also look at the howell-efi.com and see the one I
bought for the GMC. It is worth looking at.
al
> Emery:
> I would guess that Holley has fine tuned their TBI system in the intervening
> 6 years and probably inflated the cost, wouldn't you?? Any knowledge on
> what if anything they did??
> Does the Holley TBI system control spark timing using a knock sensor like
> TurboCity claims to do??
> I went to Holley's web site to look at their TBI offering. They have a
> number of them. Which system did you install?
> Do you have an opinion about the TurboCity TBI system vs. the Holley?
> When you say "It must be a high flow type", what gph rating are you
> talking??
> Paul Bartz
> From: EMERYSTORA [mailto:EMERYSTORA]
> Sent: Friday, August 13, 1999 10:02 AM
> Subject: Re: GMC: GMC Holley TBI
> I've had the Holley system for about 6 years. When I bought it the price
> was about $750 which included the closed loop system electronics and O2
> sensor. You'll definitely want the closed system because that will
> automatically adjust the fuel mixture for altitude, temp, etc.
> I've had two problems over the years. I've had a dirty fuel filter going
> into the pump which caused a starving condition that I thought was vapor
> lock at first. Don't use just any filter there. It must be a high flow
> type. The one provided by Holley is a small plastic filter but it works
> well. I tried another make first and it still starved for fuel.
> My second problem occurred last month. I suddenly lost most of my power on
> the expressway. The GMC wouldn't go over 35 to 40 mph. The engine ran well
> at low speed but would not rev up. I found that one of the two fuel
> injectors had burned out. This is an injector that plugs into the top of
> the casting that holds the two injectors. The problem was that the nearest
> one I could find was 150 miles away. I rented a car and drove 300 miles
> round trip to buy one. It was $69. I have another one on order to carry as
> a spare part. I have also carried a spare fuel pump and filters but haven't
> had to use them yet.
Paul, I agree it does havd a knock sensor, and does use the distributor we
have. but it seems to work good. I did lose an injector, but that is a holly
and I understand holly has had some problems. I used it on my last two trips,
where I went from 8,000 ft to sea level and back, and it worked fine at all
altitudes.
al
> Al:
> I've been looking at it and also sent them e-mail a couple times with no
> response.
> However, it's my understanding that the Howell system is not as
> sophisticated as the TurboCity one (e. g. doesn't have a knock sensor and
> spark timing control).
> Paul Bartz
> From: mr.c [mailto:mr.c]
> Sent: Thursday, January 14, 1999 12:30 AM
> al
> Emery:
> talking??
> Paul Bartz
Date: Thu, 12 Aug 1999 15:39:13 -0400
Subject: GMC: Holley TBI
Bruce:
I'm curious what influenced you to choose the Holley vs. Howell,
TurboCity,
etc. TBI system?
Paul Bartz
Paul
How does $400.00 sound. I frequent my local speed shop and Holley is a
pretty good name and I couldn't pass up the price. A guy had it on his
truck for 3 months, decided to trade for something else and they
wouldn't give him more for trade so he took it off.
I had decided to put a Holley on some time ago, I think it's the same
size TBI Howell was using (670 cfm), They just customized it for the
GMC(uped the cost, I don't have a problem with that, but if I can do it
myself and save the $$'s)
It is the analog system not the new digital, but I don't need the bells
and whistles. I'll ad the O-2 Sensor to make it a closed loop system.
I'll let you know how I do.
Bruce
77 Palm Beach
Sent: Thursday, August 12, 1999 3:38 PM
Subject: Re: GMC: House Batteries
In the process of installing disk (gusseted Caddy) brakes, Holley TBI,
Crane
ignition, Bilstein shocks, Poly bushings and just some minor updates on
the
interior.
Emery:
talking??
Paul Bartz
Al:
response.
Paul Bartz
al
Emery:
talking??
Paul Bartz
