As far as how much voltage is required to ignite the air/fuel mixture in
the cylinders, it is somewhere near 5,000 to 7,000 volts. A properly
functioning stock HEI will produce between 35,000 and 50,000 volts to the
plugs. Aftermarket coils or modules just are not required. Save your money
for good whiskey or some such.
Jim K is right about the EBL option. The distributor used with it has
no mechanical or vacuum advance. Those curves are provided by the CPU, and
can be tailored to your specific needs,
(towing weight, final drive ratio, cam, headers, heads, compression ratio,
etc)
> Bob,
> Since your runing the Howell base with the EBL Flash ECM, the program will
> out perform any standard HEI in terms of mecanical and vac timing. That iis
> why you will gain fuel milage with the EBL that the other so call EFI
> cannot deliver.
> Your HEI distributor runs a 7 pin module that is signaled by the ECM with
> the EBL so the Vac and Mech advance is not used.
> > > This is an area that I've never paid any attention too. As to the GMC.
> > From what I've heard. The distributors used in our GMC's. Is different
> > > then those used in cars that use the 403, or 455. That difference has
> > to be in the advance curves. I pulled the distributor out of my 78 403.
> > > Because I installed an EFI system with spark control. In the cast of
> > the EFI. Car distributors are fine. A friend wants to put a HEI
> distributor
> > > in his 73 455. I would thing that the advance cures between the 403/455
> > have to be very close. If not the same.
> > > Bob Dunahugh
> > Bob,
> > Tell him to not bother unless he is also going to go the EFI with knock
> > controlled spark.
> > If he gets a Pertronix 1181LS, it will do as well.
> > If he thinks he wants more spark power, put in anybody's real CDI and
> good
> > wires.
> > This way, he won't have to hammer the air filter housing or find another
> > that fits.
> > I did this 70K and 14 years ago and the only trouble I have had was with
> > the MSD CDI that failed. So now I am using a 1974 Delta MarkX and it has
> > been
> > flawless. I run an 0.060 gap - just don't mess with the wires.
> > Matt
> > Matt & Mary Colie - '73 Glacier 23 - Members GMCMI, GMCGL, GMCES
> > Electronically Controlled Quiet Engine Cooling Fan
> > OE Rear Drum Brakes with Applied Control Arms
> > SE Michigan - Twixt A2 and Detroit
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk
http://www.appliedgmc.com
> 1-800-752-7502
