I'm not an expert at electric fuel pumps but I have experienced
pumps that exhibit the symptoms you are describing. One type of pump that I
have owned, I believe it was a walbro would pump fuel until a desired
pressure was reached and then shut off. You could adjust the pressure with
a small screw to obtain the correct pressure for your carb etc. The other
type of fuel pump I purchased at fleet farm. This pump runs continuously.
It is indeed quite annoying as you have described. Anyway, hope this info
is useful.
Mike
is useful.
Mike
