Fred, a few years back I also mounted the sending unit for an oil temp
gauge in the oil filter adapter, measuring the oil temp leaving the
engine. I also found my oil temp ran around 260 degrees F with a normal
engine load on my 455 engine in a 76 Royale. I became very concerned an
spent a lot of money for an auxiliary engine oil cooler. At the same
time I put on several "Westac" gauges. They mounted the sending unit for
the engine oil temp in my drain plug (only charged 5$ above the normal
sending unit price). I calibrated all my temp gauges in cooking oil
before I put them in. What I found out was I spent a lot of money for
the auxiliary oil cooler that I probably didn't need. I still have the
temp gauge in the oil filter adapter and it normally runs from 40 to 60
degrees F higher than the oil pan temp. I also have another oil temp
gauge in oil filter adapter measuring the oil temp coming from my
auxiliary cooler. During normal operations the oil is cooled about 40 to
50 degrees F going through the cooler. My oil temp measured in the oil
pan drain plug never gets more than about 15 degrees above the engine
coolant temp under max load conditions.
Based on my experience with an oil temp sending unit mounted in the oil
filter adapter, your 260 degrees F coming out of the engine is about
normal.
Chuck Aulgur
GMCWS Tech V. P.
La Mesa, CA
normal.
Chuck Aulgur
GMCWS Tech V. P.
La Mesa, CA
