I have a problem with my '78 electro level I system. The passenger side
does NOT go up or down when set to 'AUTO', Drivers side responds as
expected. At first I thought it was the valve that opens up the line to
the bag, but the system works perfect when in 'HOLD' mode and using the
RAISE/LOWER manual switch. This makes me think that the valves are OK but
the rocker switch (DPDT) is not good when in AUTO setting. There is
something about a diode in the line from the switch to the valve. Could it
be bad?? Anyone with experiance like this??
