GMC Electric Wipers
19,428
5
38
Attention All Users of Electric Wiper Motors
As a result of a power steering system failure I recently experienced, I've
just created GMC Electric Wiper Instructions - Rev 4.18. The main feature
of that revision is the inclusion of the paragraph italicized below:
*This installation replaces the OEM hydraulic wiper motor with its
integrated power steering fluid filter. That filter should probably be
replaced with an in-line filter installed in the return line from the power
steering box to the pump reservoir. A large, metal-bodied filter is
recommended; clogging of that filter can result in high fluid pressure in
unintended locations and consequent failure of the power steering.*
While the absence of a filter has not resulted in any failures of which I'm
aware, it is good practice to include an adequate filter in any active
hydraulic system. Most vehicles seem to include one in their power
steering systems these days.
Your choice -- it will be a slightly messy chore, but may protect your
hydraulic system from premature wear.
Ken Henderson
GMC Electric Wiper Upgrade Inventor/Seller
Shortcut to new instructions?
JR Wright
> Ken Henderson
Not yet. I have to get them to bdub for posting on the web site. There
are only a few, nonessential, words in addition to that paragraph.
> JR Wright
> > On May 23, 2021, at 9:30 AM, Ken Henderson
> I've
> feature
> power
> I'm
> > Ken Henderson
How can you adjust the wiper sweep with the electric wipers without having
it stop 1/4 of the way up the windshield?
On Sun, May 23, 2021 at 7:34 AM Ken Henderson
> Ken H.
> > JR Wright
> > I've
> > feature
> > power
> in
> > I'm
> > > Ken Henderson
> > > GMCnet mailing list
O: 503-987-8776 C: 503-740-7737
Lawrence
*CCB#*: 212656 *WALIC#*: JUSTR**813Q7
*NRPP#*:110989 RMT *NRSB#: *200G006
First off, you need to check where the wiper motor arm is positioned when
the blades are parked. If it's not at the 6:30 o'clock position, you need
to turn the wipers OFF with the ignition ON, then reposition the arm to
that position, holding the arm with a wrench ANY time you turn the motor
nut, to protect the motor's gears. Now, if the arms are not where you want
them to park, you'll have to remove the arms from their pivots and
reposition them.
You'll have to wet the windshield thoroughly before testing the results,
and even that won't fully simulate driving in a heavy rainstorm. You may
have to make further minor adjustments after such an event. There are two
other adjustments available for that purpose:
1. The linkage between the motor arm and the idler assembly adjusts the
POSITION of the sweep arc only (If you adjust that, be SURE to tighten the
jam nuts before going for a test drive -- the parts WILL loosen themselves
and become lost).
2. The three holes in the arm of the idler assembly are for adjustment of
the WIDTH of the sweep arc. The closer the linkage is attached to the
pivot of the assembly, the wider the sweep arc will be, and vice-versa. If
that adjustment does not give you sufficient range, or granularity, making
the linkage attachment hole in the motor arm slightly oval, toward the
motor shaft, will provide a narrower arc and the linkage can be tightened
anywhere within that oval for fine tuning. Those geometric relationships
require a little concentration to keep straight.
Don't try to make the wipers sweep too far to the outside, via either arc
width or position -- at high speed, the movement up the slope of the
outside windshield will impart a force vector away from the surface of the
glass and the blades will actually lift from the glass for part of their
arc.
HTH, if not, try me again.
On Sun, May 23, 2021 at 2:41 PM Lawrence Belland
> > Ken H.
> > > JR Wright
> experienced,
> > > I've
> > > feature
> be
> > > power
> pressure
> > in
> which
> > > I'm
> active
> your
> > > > Ken Henderson
> > > > GMCnet mailing list
> > > GMCnet mailing list
> Lawrence
See what I mean by "Those geometric relationships require a little
concentration to keep straight."? I GOT IT WRONG! To INCREASE the sweep
arc width, move the linkage AWAY from the idler pivot. Likewise the motor
end of the linkage needs to move AWAY from the motor for MORE arc. I
shouldn't try to think in the middle of the night -- MAYBE I've got it
right this morning. :-)
Try it, you'll figure it out!
On Sun, May 23, 2021 at 4:48 PM Ken Henderson
> reposition them.
> and become lost).
> arc.
> Ken H.
>> > Ken H.
>> > On Sun, May 23, 2021 at 9:39 AM John Wright
>> > > JR Wright
>> experienced,
>> > > I've
>> > > feature
>> be
>> the
>> > > power
>> pressure
>> > in
>> which
>> > > I'm
>> active
>> your
>> > > > Ken Henderson
>> > > > GMCnet mailing list
>> > > GMCnet mailing list
>> > GMCnet mailing list
>> Lawrence
