Thank you for the information. I am checking the websites out.
- -----Original Message-----
To: gmcmotorhome
Date: Monday, April 06, 1998 4:13 PM
Subject: Re: GMC: (GMC) Conversion of AC to 134A
>Marcus,
> Don't do it. You'll be sorry in the long run. The R-134A
>changeover is expensive and unnecessary. R-134A is only about 50% as
>efficient because of it's higher required working pressures and
>different boiling point. It also requires the following:
>1) An oil change to PAG oil. The ester oil used in R12 systems is not
>soluble in R-134A. PAG oil is corrosive, so the whole refrigeration
>system will turn into junk in 7-10 years.
>2) Replace all A/C hoses with teflon lined hoses. R-134A has a smaller
>molecular size and will leak out faster than R-12 with regular hoses.
>3) New receiver/dryer. Needs to be changed anyway with a new charge.
>The desiccant inside will only hold a small amount of moisture.
>4) Sometimes a new compressor is required if the original one is down on
>compression. The R-134A requires almost double the working pressures as
>R-12. If your compressor is weak, it will not be up to the task.
> Here's some solutions:
http://www.frigc.com/ (This is one of the best I've seen.)
http://www.btt.org/EC-12a.html
> The Frigc is 100% compatible with R-12 systems and even more
>efficient. The EC-12 is a substitute made from organic gasses. They
>are referred to as "drop-in" refrigerants. They allow you to keep your
>system the way it is and save money while keeping it's original
>performance.
>Stay Cool...
>-Scott Woodworth
