GMC carburetor fuel to air ratio
thomas g. warner
1,863
If the analyzer was correct than I don't see how you could have cracked the
manifolds after the new carb was installed. Exception I believe was if you
were really pulling hard or driving fast for an extended time and than
promptly shut off the engine.
>Thomas Warner wrote regarding the GMC Exhaust Mainiolds:
>> If you have cracked a manifold you are almost surely running a very lean
>> mixture. If the original carb is on the coach than with todays gas it is to
>> lean. You need to get your exhaust analyzed and change the jets etc as
>> necessary to get the mixture right.
>So I'm wondering, Thomas or anyone else listening, what should the air
>to fuel ratio (F/A) be to get the correct mixture and avoid this and any
>other problems with the 455 running too lean ? I recently had my OEM
>carb recalibrated with different jets and metering rods in the primaries
>and afterwards the engine exhaust analyzer said it was running at a F/A
>of about 14.9 at 55 to 60 mph at Michigan altitude (600 to 700 ft msl I
>believe).
>Phil Stewart
>'76 Transmode
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
believe).
Phil Stewart
'76 Transmode
