> > Does anyone know of a source for Stainless Steel brake lines?
> > I will make my own if I have to, but thought I would check to see
> > if there are any premade ones out there.
Try:
Stainless Steel Brakes Corporation
11470 Main Road
Clarence, New York 14031
800-448-7722
I had some custom lenght SS lines made up for a frame-off truck
restoration project. You need to supply them with the correct lenght.
Standard double-flare tools can not handle SS tubing. They use a special
press at SSBC. You can then bend the pre-assembled SS lines with
traditional brake line bending tools.
Both the tubing and end fitting are stainless. Quality is very good.
As you can imagine, you get what you pay for.
Hope that helps
Gary
