I was working on my 76 Palm Beach today trying to get it ready for its
maiden voyage in two weeks. The alternator stopped working. I removed
the alternator and had it tested at the local Checker auto and found that
it was fine. (I put in a new one though, the bearings seemed to be a
little questionable). I tested the #2 lead from the alternator to the
battery junction block and it was fine. I haven't been able to find
where the #1 lead goes to. However, like the manual said, I tested all
three leads from the alternator with the ignition key in the on position.
The #3 lead to the battery showed no voltage. The #1 lead to the dash
light showed 2.4 volts. The #2 lead to the battery junction showed 12.6
volts.
As I read the manual, there is a shutoff of power production in the
alternator if the #1 and #2 leads don't have the proper voltage coming
back into the alternator.
I can use all the help and ideas that anyone can give me on what's
causing the alternator not to put out any voltage.
Bob Fukumoto
volts.
Bob Fukumoto
