Yes, is the answer. But the previous owner did not know why you had to
throw the switch from one source, generator, to 120 land line.
This is my first GMC and I thought everyone was like mine.
Bill
> >I also have a 1978 Rayale. GFI has been replaced
> with a switch to
> >switch from generator to AC. It is located on the
> side of the rear twin
> >bed on the right side. Do you have any response to
> this? Bill C.
> >>John, I have a 78 Royale (Coachman) with a built
> in GFI in the breaker
> >>box that you switch when going from shore power to
> gen set. A decal
> >>states that this is only good for "grounded power
> supplied
> >>circutis only" (?) Data point only. Chuck D
> I don't want to tell you guys any more than I know.
> Remember, I was
> the guy who asked for some help on understanding how
> these GFIs work.
> I could see these GFIs getting pretty annoying if
> they kept tripping
> with no apparent reason. As in Edgar's case he had
> to become a
> dectective and then divide and conquer. Bill, does
> yours look like they
> took the GFI out and put a switch in? Chuck,
> sometimes when people have
> to limit the number of words to fit on a decal or a
> label, the meaning
> gets lost. Could it imply that in the on position
> (the GFI 'in' the
> circuit position) that the AC supply circuit must be
> the type where the
> neutral is grounded at the entrance box (or main
> power circuit
> distribution box)? Can anyone interprete what this
> decal writer meant?
> My lawyer detector just went off.
> Chuck does the switch just bypass the GFI? In
> otherwords, plugged in at
> your home, does everything work in both positions of
> the switch? These
> GFIs might not work so reliably on a genset since
> the cycles per second
> is not held anywhere near as closely, as on utility
> lines.
> Regards,
> John
> "I do whatever my Rice Krispies tell me to..."
> John said, from inside a 1974 Glacier on the
> Potomac, just north of the White House.
Do You Yahoo!?
Get your free @
yahoo.com address at
http://mail.yahoo.com
