The real deal is the formulation of today's gasoline, compared to what is
made today. First, there is no tetra-ethyl lead or several other long chain
hydrocarbon molecules present in today's gasoline. Today, fuel relies upon
high pressure and tiny, tiny holes in injector tips to atomize the fuel.
Our quadrajet carburetors relied upon light weight, highly volatile
aromatic compounds that vaporized by pressure differential (vacuum) in the
venturi of the carburetor. Those compounds have been omitted in today's
fuels, the result being that incomplete vaporization occurs in a carburetor
(any carburetor, not just quadrajets) You can not adjust or "tune" your
carburetor for this. You just have to live with what comes out of that pump
nozzle. It sucks, but that is the reality of what the EPA stuck us with.
On Mon, May 20, 2019, 3:55 PM Bill Wevers via Gmclist <
> I used some parts from my 1972 Revcon carburetor to rebuild my 1975 GMC
> carb.
> They are very similar. I think the jetting might be different (the primary
> rods
> and jets).
> The vacuum break from the Revcon fits my 1975 GMC. The conversion to
> electric choke
> requires blocking the choke heater tube inlet. And no gasket is used on
> the electric
> choke thermostat. You have to carefully align the primary rods,
> accelerator pump
> and choke linkage as you put the air horn back on top of the main body.
> The fuel
> bowl float seat needs to be tight so it won't leak. But you have to be
> careful
> not to strip the threads. And the accelerator pump linkage pivot is easy
> to snap
> off if you use too much force. The threads on the fuel filter are also
> easy to
> strip if you over tighten the nut.
> The secondary air valve cam usually has to be replaced. And the air valve
> spring
> has to be adjusted a certain amount, otherwise it might bog when you stomp
> on it.
> Assembling the choke is not too difficult. But you need to adjust the
> vacuum break
> linkage to open the choke when manifold vacuum reaches a certain level.
> If you've never rebuilt a carburetor before, it can be challenging.
> In that case, it would be good to pay a professional to rebuild it.
> Bill Wevers GMC49ers, GMC Western States
> 1975 Glenbrook - Manny Powerdrive, OneTon
> 455 F Block, G heads
> San Jose
