Good point. Another thing to worry about
Is there anyone on the net that has installed the Cinnebar Solution, i.e.
Generac (or know someone that has ? ).
Heinz
>You may want to take into consideration in your replacement planning
>schedule that according to recent newspaper stories, due to Y2K concerns,
>generators are in short supply. I would guess that supply affects
prices???
> Paul Bartz
>From: Heinz Wittenbecher
>Sent: 3/2/99 7:55 PM
>Subject: Re: GMC: GenSet replacement ( again ;-)
>The big thing with the Honda is the the EV6010 and EV4010 are
>watercooled,
>which in itself should make them quiter.
>Any other Honda would be aircooled I believe and therefore noisier.
>Cinnebar does a Generac Kit (I think) and they claim it's quieter than
>the
>Honda with their special enclosure. That special enclosure makes it an
>item
>only for Cinnebar to install, i.e. not recommended for do-it-youselfers.
>They're a long 'ways away from me so the Honda seems a likely choice.
>I think I've seem them around 25-2600 dollars.
>I wonder how many are considering a Honda in their future. Perhaps we
>can
>negotiate with one of the smaller dealers (or the bigger ones) and have
>a
>GenSet fest somewhere
>I'm going to have to do something soon as my Onan gave up altogether.
>Heinz
>>>My EV6010 in Sacramento fell through so I'm on the prowl again.
>>>Thought I'd check to see if any bargains or thoughts pro and con re
>>>Honda or any other brand are lurking in the wings.
>>Hi Heinz...
>>I was following your Honda scouting and making notes because I and
>maybe
>>others will be doing a similar replacement one day. On thing that
>>baffled me, an I would welcome any enlightenment on, is the following:
>>My catalogs show the 6KW Honda and Onan around $2000 to $3000, whereas
>>there are others like a Generac 6850 watt electric start for $1249. The
>>size is 28Lx18Wx24H. Is that too big? What am I missing except they
>are
>>not as quiet as the Onan? There is a Dyna 13 HP Honda powereed 6800
>>watt with electric start that is 27L x 20W x 19.9H for $1699. I note
>>that the Honda is only 15.25 in Height. Is that the critical factor?
>>Regards,
>>John 74 Glacier
