generator problem
donald w ogden
6
Sounds like the diode bridge rectifier is blown. This can happen
suddenly if you shut down the generator while there is a load on it (like
the A/C). There may be some info on Gene's site. I can't help you much
without doing some research myself.
Don Ogden
________________________________________________________________
YOU'RE PAYING TOO MUCH FOR THE INTERNET!
Juno now offers FREE Internet Access!
Try it today - there's no risk! For your FREE software, visit:
http://dl.www.juno.com/get/tagj.
I have had this problem for two reasons:
1) Check the circuit breaker on the top of the unit. Mine had a catastrophic
failure (IE not just tripped, but fried to a crisp) and had to be replaced.
2) The bridge rectifier may have failed. If this is the case, there are some
'generic' replacements that have been listed here, or Onan may have the
original plug-compatible part (they did 18 months ago when mine failed).
If you get the replacement, you will need to rework the connector, and as
such, the original part is much easier to install. It is inside the
actual generator housing at the rear right of the unit, as you face it.
This CAN be replaced with no more than a screwdriver, and possible a pair
of pliers (as I recall) in 10 minutes or so. (I know, I changed mine on the
road on the fly when the breaker failed, but before I figured out that the
failure really was just a breaker.) I would also suggest putting some
heat sink compund on the new part to enable it to cool to the genset
casting more efficiently.
- - Tim
> Something strange just started to happen with my Onan Generator. The
> generator runs fine but it is not sending any juice to the coach. It was
> working fine last week??? Any sugestions
> p.s. I recently added a new battery???
> Rob Mudd
> Cowtown
> ________________________________________________________________________
> Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com
Tim Dawson (tadawson) Owner/Engineer
TPC Services Bellnet: (972)-221-7385
Lewisville, Texas 75067 FAXnet: (972)-221-0393
"The world is complex. Sendmail.cf reflects this...."
