Gauges - digi-panel trans sensor
Totality
575
Planning to add digi-panel to my GMC and want to know which trans cooling line is better, in or out. Jim seems to recommend the in line and the
instruction recommend the out line.
So which line do most of you use? Any one got video or pictures of installing the panel in general or the sensors in particular.
Pete
> Keep in mind that what is important is to know the temp of the fluid being
> pumped into the trans.
> Should you want to monitor the out temp, it will be very high when a load
> is placed.
> >> Here is what I did. This pic and the next two tell my story. Been this
> > way for 13 yrs. No issues.
> >> http://www.gmcmhphotos.com/photos/transmission-install/p3851.html
> >> JWID
> > OH, BTW, I put the sensor in the front right corner of the pan because
> > that is where the most clearance is. Can't pick just any spot. The sensor
> > will interfere with the valve body, so look carefully before you drill.
> > Larry
> > 78 Royale w/500 Caddy
> > Menomonie, WI.
> Jim Kanomata
> Applied/GMC, Newark,CA
> jimk
> http://www.appliedgmc.com
> 1-800-752-7502
Cary, NC
1978 Center Kitchen Royale.
Since the in line tells you the temperature after it is cooled I don’t think that tells you much.
The out line, however, will tell you if the transmission is overheating.
Emery Stora
77 Kingsley
Frederick, CO
> Pete
>> is placed.
>>>> JWID
>>> Larry
>>> Menomonie, WI.
>>> GMCnet mailing list
>> Jim Kanomata
>> jimk
>> 1-800-752-7502
>> GMCnet mailing list
> Cary, NC
Pete,
At one time or another, I've monitored In, Out, and In-Pan. They all do
read differently, as you'd expect. Now, I monitor only In-Pan. If you
read the Chevrolet P-30 Chassis Owner's Manual (available at bdub.net),
there's an appendix dedicated to automatic transmissions, including cooler
and filter installation recommendations, and quite a good discussion of ATF
temperatures, including a table of predicted ATF Service Life vs Average
Temperature IN THE PAN. That's enough to satisfy me that the important
temperature is In-Pan.
> Pete
> being
> > is placed.
> this
> > >> JWID
> sensor
> drill.
> > > Larry
> > > Menomonie, WI.
> > > GMCnet mailing list
> > Jim Kanomata
> > jimk
> > 1-800-752-7502
> Cary, NC
Most transmission techs will tell you that what is important is the
temperature of the fluid that is picked up by the transmission and run
through it.
Pan temp is what I recommend.
We have found that the Ragusa Al.pan not only carries more fluid, but the
cooling fins in both inside and outside does very good job of dissipating
the heat.
> Emery Stora
> 77 Kingsley
> Frederick, CO
> and the
> > Pete
> being
> load
> >> is placed.
> this
> >>>> JWID
> sensor
> >>> Larry
> >>> Menomonie, WI.
> >>> GMCnet mailing list
> >> Jim Kanomata
> >> jimk
> >> 1-800-752-7502
> >> GMCnet mailing list
> > Cary, NC
I agree with Jim on this. My Mac dash has a separate transmission gauge which has a probe in my Ragusa pan that tell the oil temp in the pan.
By the way, my Ragusa pan has never weeped fluid.
Emery Stora
> through it.
> the heat.
>> Emery Stora
>> 77 Kingsley
>> Frederick, CO
>> and the
>>> Pete
>> being
>> load
>>>> is placed.
>> this
>>>>>> JWID
>> sensor
>>>>> Larry
>>>>> Menomonie, WI.
>>>>> GMCnet mailing list
>>>> Jim Kanomata
>>>> jimk
>>>> 1-800-752-7502
>>>> GMCnet mailing list
>>> Cary, NC
>>> GMCnet mailing list
>> GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
Well I have a Ragusa pan on mine thanks to a PO, it doesn't have any obvious leaks either, can I simply place the sensor under one of the mounting
bolts?
Pete
Cary, NC
DigiPanel are the easiest gages to attach without needing any adapters. The
feature that customers love the warning buzz when the danger levels are
almost reached.
Few had a leaking oil hose and lost oil pressure and the buzzer went off at
5-15 psi and they shut off the engine befor any damage was done.
> mounting
> bolts?
> Pete
> Cary, NC
Jim,
The "standad" Digi-Panel must use the oem oil pressure sender, Art manufactured a unit that used a separate (stand alone) oil
pressure sender.
Can you have one like that made?
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Jim Kanomata
Sent: Tuesday, September 26, 2017 11:07 PM
Subject: Re: [GMCnet] Gauges - digi-panel trans sensor
DigiPanel are the easiest gages to attach without needing any adapters. The feature that customers love the most is the warning buzz
when the danger levels are almost reached. Few had a leaking oil hose and lost oil pressure and the buzzer went off at 5-15 psi and
As long as we can supply the sensor so we can be sure the value of the
sensor matches for accuracy.
There will be additional labor charge around $ 35 labor plus sensor.
On Wed, Sep 27, 2017 at 4:28 AM, Rob Mueller
wrote:
> Jim,
> pressure sender.
> Regards,
> Rob M.
> Sydney, Australia
> Kanomata
> To: gmclist
> Jim Kanomata
> jimk
> 1-800-752-7502
Jim,
Thanks!
I will contact you off net with shipping and payment details.
Regards,
Rob M.
Sydney, Australia
Sent: Wednesday, September 27, 2017 10:56 PM
wrote:
> Jim,
> pressure sender.
> Regards,
> Rob
What's the advantage in doing it that way?
Pete
> Jim,
> pressure sender.
> Regards,
> Rob M.
> Sydney, Australia
> To: gmclist
> Jim Kanomata
> jimk
> 1-800-752-7502
Cary, NC
Redundancy - It's not tied into the GMC instruments.
In my opinion the best gauges are direct reading mechanical gauges. For example an oil pressure gauge that has a line filled with
oil that connects the engine oil supply system to a gauge with a Bourdon tube.
Tiny URL: http://tinyurl.com/y7eoqsgs
Full URL:
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&ved=0ahUKEwj18q-fmMnWAhWI0RoKHZw5CmAQjRwIBw&url=htt
p%3A%2F%2Fwww.instrumentationtoday.com%2Fbourdon-tube%2F2011%2F09%2F&psig=AFQjCNEOfh2v5TrtUI5t6UKF5i_2ryItYw&ust=1506733065849287
Regards,
Rob M.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Pete Smith
Sent: Thursday, September 28, 2017 7:48 PM
Pete
