> I have a 1974 260 unit with dual 25 gallon tanks. I am confused as to how the fuel pump draws gas from both the rear main tank and the front aux
> tank when the dash switch is in the fuel main position. Anyone have a explanation of how this works?
Ken,
Welcome to the group, family, cult, asylum...
How does this work?
Short answer - Very well. If you track your fuel rate (write the odo on each slip and build a spreadsheet, you will quickly find that each tank is
highly variable due to the bad fills. But if you fix that (search here - recommending high T), your fuel fills can be very regular.
The cross-connection of the mid-tank fill pipe is a lot of your confusion and it is understandable.
Now, what we do is:
Run on the main until half and change over so there is no old fuel left in the auxiliary tank.
If the light comes on, go back to the main that will still have about 10 gallons in it. That is also enough for about 5 hours of APU time.
Buy fuel at 400~450 miles. Street Atlas will tell you where to start looking at GasBuddy. (Street Atlas is out of print and the nearest I have found
is Furkot and that is a website application and so of limited (aka useless to most) underway.)
There is another problem, most of the tanks selector valves have gone bad because of the addition of alcohol to mototfuel to support ADM and a very
few farmers. The available replacements work, but are very different.
Now Ken, you made it here and that is a real good thing. What you also may not have yet grasped is that you just collected a couple of thousand brand
new old friends. Your coach is much more than a big new toy. You will soon realize that being an owner of a GMC ties you to a community like few
others. This is why you need to go back to Bdub's and collect and print a copy of the Black (aka GMC Assist) list. When you need assistance, there
is probably someone in striking range. These are amazing and very supportive people. For all this to work, you need to do both yourself and us a big
favor. If you read down the way, you will see that we all have sigfiles. This is more than just a fad, there is a reason. That reason is so we can
help each other.
To make a sigfile, go to and scroll down. You will find the place to fill it in. This forum is a mirror of an
E-mail list and even some that have high speed broad band (and indoor plumbing) still prefer to rear this as e-mail. They don't get to see the header
at all. To that end, please start with a real name (so that when you meet others, they don't have to guess who you are), a short about the coach
(year, version and major mods) and a geographic reference (so others will know if they can come and help).
Again, this is a community like few others. In actual fact, the only other that I know of is that of the watermen of my world. For this reason, I
like to welcome new owners here much as a new owner or vessel is welcomed there. So,
May the Good Lord bless this coach and all those that set forth within her.
Welcome Ken
