Years back I could not get them out with a hex wrench. I finally used a small pipe on the two or three threads showing. They turned right out.
Frederick CO
> Proceed with extreme caution on those drain plugs. More often than not,
> they are not loose, but are seeping fuel around the outside perimeter of
> the fitting. I use a 3/8" drive breaker bar with an Allen socket. Sneak up
> on the torque by gradually increasing your pull on the breaker bar. If it
> won't budge, clean the area thoroughly, and wipe it clean and inspect to
> see what you have. If it leaks around the fitting, try epoxy.
> Salem, Oregon
> On Tue, Oct 8, 2019, 10:17 AM Jeffrey Fleming via Gmclist <
>> I need to tighten mine as it has a slight leak . It looks like an Allen
>> key type fitting can anybody tell me what size it is. I believe they are
>> stock
>> Thanks
>> Jeff
>> Jeffrey Fleming
>> 1976 edgemonte
>> Living in Maine
