Gas tank cleaning up date.
Bob Dunahugh
2,784
4
3
Ken Shaffer is the owner of the GMC that had the contaminated/rusty gas tanks. Going to do it again with two tanks that I have that are in that same condition. Then wright up how we get it done again. Ken bent up a piece of 1/8"X 1"X 18" flat. Screwed one end to a piece of plywood to support the steel flat so it wouldn't come in contact with the tank. Then attached a 12V 30 Amp battery charger. With the neg to the tank, and posi to the steel flat. Did that for about 12 hours. Had to clean the rust build up on flat off every few hours. Let me know if you want photos privately. Bob Dunahugh
I am very interested in what you did. What kind of liquid was in the tank while you did this? Please forward pictures.
A friend who likes old cars told me that shaking a tank with washed crushed
rock chips inside will remove scale/rust from inside the tank. I have not
tried it but he claims to have done it successfully.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
*John Phillips*
Ken, I've used Arm and Hammer Super Washing Soda using about 3 tbls per gallon of water. I just used a battery charger hooking one lead to the
sacrificial metal and the other to the piece you need cleaned. It's important to hook the + terminal to your sacrificial metal and - to the tank. You
need to keep an eye on things as it will evaporate the water pretty quickly.
I've used it to clean (remove rust) from seat tracks which are really tough to clean and had good results. Almost seems like 'magic' when you see it
working.
Have fun, Hal
1977 Royale 101348,
1975 Eleganza II, 101230
1974 Eagle Bus 45',w/slideout
Ken,
Peter Bailey cleaned his tanks with molasses.
Regards,
Rob M.
The Pedantic Mechanic
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Ken Burton
Sent: Wednesday, August 30, 2017 5:02 PM
Subject: Re: [GMCnet] Gas tank cleaning up date.
I've cleaned countless motorcycle tanks.
Anything acidic will work.
Lemon juice, vinegar, etc.
Hydrochloric works best (muriatic acid).
It will make very quick work of rust in a steel tank. You then have to rinse, and neutralize with a base (baking soda works) and then get a light
coating of oil or similar on the metal to prevent flash Rusting.
Justin Brady
http://www.thegmcrv.com/
1976 Palm Beach 455
As listed below. If you'd like some photos. Please send request direct to me privately. As photos can't be sent here. Bob
Sent: Tuesday, August 29, 2017 12:33 AM
Subject: Gas tank cleaning up date.
Even ether post the photos on our gmc web site and publish them FOREVER...
> From: Bob Dunahugh
> To: gmclist
Alternator Protection Cable
Sent: Thursday, August 31, 2017 10:39 PM
To: Emery Stora
Subject: RE: [GMCnet] Gas tank cleaning up date.
I asked Ken to put this in order. As I wasn't there all the time. I posted the photos on the EFI list. If interested. E-mail me privately. Bob Dunahugh
Sent: Thursday, August 31, 2017 1:15 PM
To: Bob Dunahugh
Subject: Fwd: [GMCnet] Gas tank cleaning up date.
---------- Forwarded message ----------
Date: Wed, Aug 30, 2017 at 11:21 AM
This was kind of an experiment for me but it worked out very well. I saw a video online about tank cleaning with electrolysis and thought it was interesting.....so i tried it. I first power washed the tanks with a Hotey to get the first layer off. they were pretty bad.
1) Dissolve washing soda (Walmart laundry detergent isle) 2oz / gallon of water in plastic 5g bucket.
2) With tanks on ground and fill hole slightly lifted, pour water into sending unit opening. Fill tank.
3) put metal anode into sending unit opening. I made anode from 1/8"x 1" x 24" steel strap bent into S patterns to zig zag into tank.
4) important to make sure anode does not rest on any part of the tank when hooked up to battery charger. I cut a chunk of 3/4" plywood approx 18"x18" to lay flat on top of tank. Then I screwed anode into plywood to hold it into place and hang in tank.
5) clamp positive clamp of 30amp battery charger to anode, clamp neg to outside of tank to ground it.
6) let run for 8 hours. It will generate some rusty/crusty gunk and it will collect onto anode
7) remove anode, clean it off with wire brush and repeat. (same water)
8) I did this process for approx 24 hours / tank
9) dump water and gunk out of tanks, rinse well with power washer. pour in a couple bottles of isopropyl heat (red bottle) to help remove remaining water. fan dry.
10) install tanks and put gas into tanks as soon as possible to deter bare metal tanks from rusting again.
again, this was an experiment for me that worked pretty well. I have included a few pics for you to see process.
Hope this helps and good luck.
Ken Shaffer
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
*John Phillips*
I tried the "scrub it out" method using hardware (washers and 1/4-20 nuts). It did a fairly good job. Problem is getting the "stuff" (rocks or
hardware) out after it's done it's job. I have one spare I'm still trying to get the hardware out of. I work on getting the hardware out when I feel
I can tolerate the frustration for a while.
GMCMH tanks are different in that they are so wide, so shallow and have internal baffles.
Steve Southworth
Palmyra WI
I will be interested in how this works out. The theory, and my experience, with electrolytic rust removal is that it is pretty much a "line of
sight" process. The electrode can only clean what it can "see". I am curious as to how the tank section "behind" the baffles get derusted. Is it
truly a "line of sight process" or just one where the electrode can clean what it can "illuminate" in the interior.
Steve Southworth
Palmyra WI
Steve,
Being that I am a lazy bastard I just brought the tanks out of The Blue Streak to Redi-Strip here in Sydney and for $400.00 I got
them back with absolutely no rust in them!
I have a flexible borescope I used to check ever nook and cranny and found NADA!
Unfortunately one of the tanks has more holes in it than Swiss cheese so I am not sure how to proceed.
I am preparing to head for the USA over the weekend (I fly out Monday AM) and don't have time to go down to my workshop and take
photos.
Regards,
Rob M.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Steve Southworth
Sent: Friday, September 1, 2017 6:18 PM
"stuff" (rocks or hardware) out after it's done it's job. I have one spare I'm still trying to get the hardware out of. I work on
getting the hardware out when I feel I can tolerate the frustration for a while.
Steve Southworth
I've tried several rust removal recipes over the years which include molasses, battery charger and washing soda, muriatic acid, vinegar, etc.
The one I like the best is the vinegar as it is the cheapest, least amount of mess, and the acid isn't strong enough to be a risk. All the processes I've tried take soaking time with the exception of the muriatic, which only takes minutes in comparison, but is very harsh on the metal and everything in the vicinity.
I use pickling vinegar and re-use the solution a couple of times before heavily diluting it and pouring down the drain.
Les Burt
Montreal
'75 Eleganza 26'
> Steve,
> photos.
> Regards,
> Rob M.
> Sydney, Australia
> To: gmclist
> Steve Southworth
> Steve,
> Rob M.
> From Steve Southworth
Rob - agree on chemical strip. After my resounding success using hardware I took the rest of the tanks to a local rust stripping outfit. They came
out exactly like yours. Ten years ago it only cost me $100 each.
As to the Swiss cheese I would take it to a radiator repair shop and see if they can close up the holes. Then POR the insides and chassis saver on
the outside. If they are just pin holes the two coatings may be enough.
Steve Southworth
Palmyra WI
Steve,
Labor costs are WAY higher Downunder the national minimum wage is currently $18.29 per hour as compared to $7.25 in the USA.
I may have a go at fixing it my self by brazing up the holes and the follow what you noted below.
Regards,
Rob M.
Sydney, Australia
Sent: Saturday, September 2, 2017 10:14 AM
outfit. They came out exactly like yours. Ten years ago it only cost me $100 each.
chassis saver on the outside. If they are just pin holes the two coatings may be enough.
Steve Southworth
Palmyra WI
Rob,
Don't bother brazing, use solder and flux as it needs less heat and is fairly quick once you've perfected your technique. That is what most rad shops would do.
A faster alternative is a thick epoxy like JB weld. It can be applied with a plastic trowel to seal the holes. Once done with the holes, Use tank sealer for the inside and a good rust paint for the exterior and the tanks will outlive the owner.
Les Burt
Montreal
'75 Eleganza 26'
>> Steve,
>> Rob M.
> Steve Southworth
> Palmyra WI
Les,
The tank is FULL little rusted through holes, I'd say there are possibly 100 of them. The tank has already been repaired with brazed
spots and soldered spots. I have two spare tanks here in Houston and I'm checking into the cost to have them sea freighted to
Sydney.
BTW this is a self inflicted wound, I left the tanks with a small amount of petrol in them and voila le problem!
Regards,
Rob M.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of Les Burt
Sent: Thursday, September 7, 2017 10:03 AM
Rob,
Les Burt
Montreal
'75 Eleganza 26'
I'd still give the epoxy a try before giving up on the tank. Brazing or soldering will be a long job that might test your patience and stamina.
If the holes are truly just pinholes, you could cover them with masking tape and then apply a tank sealer to the inside. Once the sealer has been thoroughly cured, the tape can be removed and the exterior painted. The sealer will bridge the pinholes easily with the tape in place. The tape stops the sealer from leaking out and supports it until cured.
Les Burt
Montreal
'75 Eleganza 26'
> Les,
> Sydney.
> Regards,
> Rob M.
> Sydney, Australia
> To: gmclist
> Rob,
> Les Burt
> Montreal
> '75 Eleganza 26'
Rob,
Have you given up on using propane/butane as your primary fuel source?
Les Burt
Montreal
'75 Eleganza 26'
