I dropped both gas tanks and replaced all the fuel lins.
Driving the coach after this was done using the main tank and everything was fine.
After using about 1/8 tank I switched to the aux tank to use that one for a while.
After a short time (1-2 minutes) the engine started acting like it was starving for fuel.
I switched back to the main tank and the problem went away,
so since the tanks are linked and I always refuel when I use about half the fuel I figured I would just stay on the main tank.
To my surprise as I was approaching my exit on the interstate the low fuel light came on.
I looked at the gauge and the main tank was almost empty. I switched to the aux tank again and it showed almost full.
and I again started having the fuel starvation issue. I switched back to the main tank and got off at the exit and pulled into the gas station.
I filled the tank and it took 20 gallons.
My question is What could cause the fuel in the Aux tank to not drain into the main tank as you drive down the road?
Keep in mind I live in Florida and it is fairly flat.
Tom Lins
St Augustine, FL
77 GM Rear Twin, Dry Bath, 455, FI-Tech EFI
Manuals on DVD
http://www.bdub.net/tomlins/
Tom Lins
St Augustine, FL
Manuals on DVD
