I think the socks on my gas line pickup in the tank are clogged. Every
so often the engine will die down - almost cut off at speed - 55 mph.
Can I blow back tru these to check or will that blow them off. Also do I
need them if I install a hi flow inline gas filter ahead of the
switchover valve. Any response is welcome, this problem also has made it
necessary to install vacuum pump for brakes.
Jim Hall
77PB
Jim Hall
77PB
