You have to look at the "GAS OUT" at a very local and short level if you
would. Not an over all consumption rate etc.. In the Nixon era, when he
decided to replenish the US of A natural resources of oil. Which at up to
then; when the oil was pumped out, sea water was pumbed in. Obviously to
assist in keeping TERA FIRMA in the right place. Now if you will impose on
your gray matter you will REMEMBER that the harbors in Los Angles, Long
Beach where the crude came in was bumper to bumper if you will, with tankers
full of crude oil and no place to put it. We were full, Oak Hill, Santa Fe
California, Signal Hill and the rest of these old oil fields were just as
full of crude as they were before it was discovered and pumped out. This
was the case across the entire oil fields in these United States. Oklahoma,
Wyoming, Utah Louisiana, Texas and the rest of the fields. The reason the
Gas Crisis then, was there were no plants cracking or making gasoline at
that instant in time. If we really want to draw attention... LOCALLY...,
and it will be noticed, do not buy gasoline for three days, or longer if you
can. Now just stop and think where the production for gasoline starts.
Right the crude comes into the US then it goes to the plants that make
gasoline. Remember there is no room to put any more crude in the ground.
And, the US is using a specific amount of gas say 80 Billion barrels a day.
Just to make gasoline, not paint thinner or plastic or any of the rest of
the stuff crude is used for. That is just gasoline. now don't buy any and
where is the gasoline truck tankers going to put it. Not into full gas
stations. That is for certain. Yes! if we can all get together, and that
is a mammoth obstacle in itself. Because Americans do not believe in
helping thy neighbor as thy self. Most are stingy crummy selfish
self-serving, you know the rest. But to make something work, give up your
PRIDE and go with the FLOW and do not let you hasty self righteousness over
rule your crumpled up BRAIN. This may hurt some feelings but that is ok
too!
too!
