> -----Original Message-----
> From: owner-gmcmotorhome
> [mailto
wner-gmcmotorhome]On Behalf Of
> LNelson208
> Sent: Monday, May 03, 1999 4:21 PM
> To: gmcmotorhome
> When I try to squeeze more gas into the tanks, it
> literally drains out from the bottom of the canister...
> A message about cleaning the fuel vapor dohinky valve
> that resides ion the area of the drivers side rear wheels. Is any of this
a part of my
> problem? Should I replace the canister? Could it be saturated?
Larry, I, too, think your "vapor dohinky" is not working correctly.
Actually, it is a float valve whose purpose is to prevent liquid gasoline
from going to the canister. I have not opened one, so I don't know if they
are serviceable. If it can not be replaced, I would try to cut it open and
see if it can be cleaned or repaired. The case is plastic, and can be glued
back together.
Scott Shean
78 Royale
Baton Rouge, LA
> [mailto
> LNelson208
> To: gmcmotorhome
a part of my
back together.
Scott Shean
78 Royale
Baton Rouge, LA
