Oops, I forgot this link:
http://www.gmcmhphotos.com/photos/aa-miscellaneous-photos/p54750-fuel-pump-inlet-filter.html
Regards,
Rob M.
Sydney, Australia
-----Original Message-----
Sent: Sunday, August 13, 2017 9:44 AM
To: 'gmclist'
Subject: RE: [GMCnet] Gas, jogging and very nice contact with a sheriff (deputy)
G'day,
Ken Frey installed a filter in the rubber hose that connects the solid line welded to the front crossmember and the mechanical fuel
pump inlet. Its a terrific idea as it keeps crap from getting into the Q-jet filter which is small and is installed "backwards"
vis-a-vis the way it should be installed. Filters should be installed so the flow goes from the outside to the inside; a larger
surface area to a smaller surface area.
Regards,
Rob M.
Sydney, Australia
From: Gmclist [mailto:gmclist-bounces] On Behalf Of roy keen
Sent: Sunday, August 13, 2017 8:27 AM
Subject: Re: [GMCnet] Gas, jogging and very nice contact with a sheriff (deputy)
When you run the tanks down too low that the light comes on switch to the other tank then keep switching to the other tank till the
light is lit period and hope you make it to a gas station in time. Also pray you don't have a grade to climb. If you drop the tanks
to replace hoses remove the socks and extend the pickups lower and add a large external fuel filter from each tank to take the place
of the socks this way you will have more fuel if you need it in a pinch. Better yet keep the tanks fuller when traveling in Nevada.
Roy
Regards,
Rob M.
Sydney, Australia
To: 'gmclist'
G'day,
Regards,
Rob M.
Sydney, Australia
Roy
