My gas pedal is fairly stiff and I suspect the cable from the floor to the
carb. When I remove the spring on the carb it doesn't loosen up. Must I
replace it or can it be lubricated?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
