> I'd like to add some additional instruments to my 1977 Royale,
> specifically transmission oil temp, battery/amp meter and tach. Any
> suggestions for what other gages might be useful?
> Recommendation for sources and installation advice? How about size, 2
> inch...5inch : )
> For those who added additional gages, where did you put them...the dash
> looks pretty full now.
> Thanks,
> John
I can help on this. Ever since I broke an oil cooler hose on my first
GMC, a '73 and would have ruined an engine, but a car behind flashed
headlights and I saw smoke and stopped 50 feet before the interstate
causeway to St. Pete, FL. I have been worried because you can't drive
and stare at guages all the time.
When VIP brought out their monitor panel I got one of the first. Has
digital readout of: Outside temp, battery voltage, oil temp, oil
pressure, engine temp, trans temp out and trans temp return from cooler.
The best feature is if any go out of range a buzzer sounds. Can be muted
temporarily with a button. I mounted panel in front of ash tray since I
don't use that. If you send snail mail address I have a picture I will
send. I also like their Towbrake since GMC does't have a lot of reserve.
I have no connection with VIP other than a being satisfied customer.
Call VIP Systems at 800-927-6778. They will send you a tape and lit.
Bill Wallace - K3SVO
