>WALA my new JC Whitney catalog came the other day. In it was a new
>add on circuit panel. You could get it with 6 to 18 circuits! I ordered the
>one with 12 fuses--------wrong! Get the one with 14. The circuits are in two
>banks. The 12 circuit one means I will have to splice a wire to go to the
>other
>side of the panel. 14 would be almost the same spacing as our original fuse
>block with 7 left to play with.
>Specs: It uses the new blade type fuses. Think I have even seen circuit
>breakers for these.
There are blade type circuit breakers available. Keep in mind that some of the breakers are longer than the fuse that they
replace, so some panels may have problems with interference.
Henry
Soquel, Ca 95073 / IP reviews
fax: (408) 462-5198
http://www.henry-davis.com
>other
>breakers for these.
Henry
fax: (408) 462-5198
