There seems to be a lot of you who are trying to change and replace
furnaces. I took a different approach to the problem. Although it is
somewhat scary I decided that I would cut a new hole for a new furnace.
You know, measure 25 times, cut it too small and file out the rest.
That's the only way I'm comfortable cutting through the side of the
coach. I went to an alternative model by using a Hydro-Flame Excalibur.
A much cooler name than Suburban. (Not a reflection on quality) By going
with the low profile HFE I was able to increase my options for
installation. Because I am replacing the cabinets et-al, I was able to
be creative. By not having a combo stove-oven and only having a low
profile cook top I was able to utilize the space between the bottom of
the cook top and the top of the fender well to install the furnace. The
only downside to this for some of you is that I had to cut a 7" x 16"
hole for the furnace. This type of furnace also gives me the luxury of
having total accessibility because the furnace is removable from the
outside. At least this configuration works well for me. I used the old
space from the old furnace for the new hot water tank. When I cut the
hole for the HWT the old holes from the old furnace went too. Darren
