furnace pix
gene
2,215
The pictures are finally up there. (twice) I guess PhotoPoint was doing
maint.
Like I said on my earlier post. That rusty snout you see in one of the
pictures is stuck into the bracket on the inside of the coach.
We took off the outside grill
put large washers on the outside to hold the inside plate like a Sandwich
with the wall of the coach in the middle.
then we got a socket that would fit inside the vent tubes from the out side
and tapped on the pipe in the center. They were rusted in quite tight.
When I put it back togeather, I used some muffler epoxy between the inner
plate and the wall of the coach so that there would be no leak into the
coach.
Hard to describe, should have taken some pictures of the final project.
gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
