I need to install an EZ lock for Linda's powered wheelchair in our 78 GMC.=
It's like a fith wheel hitch. It cost $2,200, and $800 to bolt it to the =
floor. And they say that I'm not trained to install it. So they wouldn't se=
ll it to me. Well. We had one in the burned Royale. So I went out to dig t=
hat one out of the rubble. Took the 4 bolts out. Cleaned it up. Rewired it.=
As all the components worked. Then painted it. Works perfectly fine. Now =
I need to install it without the training to drill the holes. I've been tr=
ying to figure out how I can make the plywood floor thicker/ stronger with =
the one inch foam insulation, and aluminum sheet under that floor. And the=
n keep the floor underside away from the exhaust. So I can put a heat shie=
ld above the mufflers. So this is were the next neat thing worked out. B=
ecause a 24 by 26 inch floor section is cut out due to the NEXT fire. I ca=
n install plywood were the insulation was. Then install the floor section =
back in. So now I'll have my reinforced floor section. And still have the a=
luminum sheet in place. Funny how things work out sometimes. Bob Dunahug=
h 78 Royale Mouse House
