Chuck,
Although the previous owner removed the Liquid/vapor separator it was
probably not prudent move. The liquid/vapor separator is designed to
prevent liquid gas from getting to the carbon canister. when vent the
fuel tanks and to prevent gas from running into the canister when the
tanks are full to the top. You have a situation that is unsafe and
could in the right situation cause a fire that would make an end to your
GMC. Cinnabar does sell a direct replacement unit for the GMC and as
far as I know it the only one that will do the job as designed. GMC
Motorhome Newsletter June 1999, number 20 from Cinnabar has a detailed
explanation on how it works and why. Part and the cost is $140
and is 50 state street legal for emissions.
Part phone number is 800-720-2227.
J.R. Wright
GMC GreatLakers
Michigan
> Hi!
> Started digging into the fuel system, dropping tanks, new lines etc.
> Sometime in the past, the P.O. removed the fuel vapor seperator from the
> driver's wheel well, plugged the lines and ran the vaopr line directly to the
> vapor canister.
> Looking for opinions on which way to go about this. Should I continue with this
> mod, or look for another seperator and restore it back to original? Where would
> I find a seperator? Is there another vehicle that used one of these? etc.
> Any and all opinions, ideas, etc. appreciated!
> Later!
> Chuck Esh
> 74 Sequoia
> Georgetown,
> TX
J.R. Wright
GMC GreatLakers
Michigan
> Hi!
> vapor canister.
> Later!
> Chuck Esh
> 74 Sequoia
> Georgetown,
> TX
