If someone is able and so inclined, could you do me a favor? For tools
you need an ohmmeter and access to the fuel sender wire on the back of
your dash panel. On the wiring harness on the back of your gauge cluster
there is a grey wire with a black stripe. This is your fuel sender. With
the key off, ground your ohmmeter and put the other wire of your meter
to this wire. It should read somewhere between 0 an 90 ohms, depending
on full your fuel tanks are. The higher the number the fuller your
tanks. After this part is done set the dial on your meter to read volts
for a 12v system. Turn on the ignition key, without starting, and read
the voltage if any on this same wire. Leave the wire connected to the
gauge at all times. If I don't have a problem, hopefully your meter will
read about 4 volts. If it doesn't, I have a problem. All help and
comments great fully appreciated.
Darren Paget
76 Experimental
Another Fab Day
paget
Darren Paget
76 Experimental
Another Fab Day
paget
